fuel issue - Mustang Evolution
Old 11-20-2011, 02:24 PM   #1
fuel issue
Hey guys I'm new to this amd my 94 gt is having fuel issues I believe. It runs smooth amd good but I believe it lacks power. It has 410 gears in it. But I hooked up a fp tester amd it was like 28 at idle amd 34 with the vacuum unhooked. Do y'all think I should start with the regualtor or the pump. And also my spark plugs are really clean and real white in color. So I'm guess it's running lean. If it's running lean is that a power robber?
---------- Post added at 06:24 PM ---------- Previous post was at 05:56 PM ----------
I don't know if I'm doing this right but I would appreciate if somebody posted some thing back so I know I'm doing all this right. Like I said I'm new to this forum thanks
Robbie94gt is offline   Reply With Quote
Old 11-20-2011, 02:27 PM   #2
Re: fuel issue
Your FP should be at 38-39 PSI with the vacuum unhooked.
Running lean will make power up to a point, running a bit rich is more desirable to protect your engine.
Run it to lean and you will burn a piston.
If your regulator is not adjustable, I'd replace that first.
Old 11-20-2011, 02:36 PM   #3
Ok thanks. I'll do that. So would 5 psi make that much of a differnence. Another thing is I've been reading amd y'all say to bump the timing up to about 14 or right b4 it starts pinging. Well I tried mine amd it was at 10 I bumped it up to 11 and it starting pinging so I put it backat 10. would the fuel issue make it start pinging at 11 where it's starving for fuel ?
Old 11-20-2011, 02:43 PM   #4
93slowstang's Avatar
I wouldn't bump up timing until you resolve the fuel issue. Start with your regulator first and work from there.
Old 11-20-2011, 02:53 PM   #5
Re: fuel issue
It might under full acceleration.
The pinging is from pre-ignition, the plug fires too soon before TDC.
You may have some bad gas in the tank if it pings just one degree over stock setting.
Old 11-20-2011, 03:24 PM   #6
Ok thanks guys I did change my filter and in the very bottom of it. Black stuff came out of it. But yeah I'm goinh to put a afr on it amd c what it does. But y'all think the white spark plugs r normal or cu it's running lean
Old 11-20-2011, 04:18 PM   #7
aegischief's Avatar
If ur plugs are white you are running lean. For whatever reason you are not getting enough fuel. Could be as simple as clogged fuel filter or a failing regulator. Or something more like the fuel pump. You need to be seeing around 39 psi with vacuum removed. DO NOT touch the timing till you figure out the fuel issue. It does not take much to fey a piston, even with a stock motor.
aegischief is offline   Reply With Quote
Old 11-20-2011, 04:22 PM   #8
Ok thanks for your reply. I'll keep it posted after I put the afpr on it.
95 gt fuel issue slow_stang 1979-1995 Mustang GT 22 11-16-2011 05:20 AM
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
Timing or fuel BigRed1781 1979-1995 Mustang GT 2 09-12-2011 08:53 PM
Fuel Filter replacement problem 99 SVT Cobra SVT Mustang 13 07-31-2011 07:25 AM
Fuel gauge issue macmarine39 1979-1995 Mustang GT 7 07-16-2011 05:19 PM
08:53 AM
