Timing - Mustang Evolution
Old 11-20-2011, 05:16 PM   #1
Chefnick's Avatar
Timing
I what's the best way to set the timing. Is it supposed to be set to the top of the timing bracket or do I need to place a mark on it once I find tdc or what.
Chefnick is offline   Reply With Quote
Old 11-20-2011, 06:14 PM   #2
Re: Timing
No offense, but you don't sound like you have much experience setting the timing.
You should pick up a Chilton or Haynes manual to guide you through tune ups and repairs.
You will have to put a white mark on the harmonic balancer at 10 degrees BTDC. When you point your timing light at the bracket, the mark should line up with the straight edge of the bracket on the left side when you are facing the front of the engine.
Old 11-20-2011, 07:55 PM   #3
Chefnick's Avatar
That's what I thought. I have adjusted timing before was just unshore where to line up the make with. I person that I bought the car from already placed a white mark on it and it is set like about 2 inches to the left. I'll have to take a closer look and see where on the HB he actually placed the mark
« 95 gt tuner | Mis »
Timing chain blackdreams15 1996-2004 Mustang GT 3 11-11-2011 07:15 AM
Timing advanced. 89 Foxloco 1979-1995 Mustang GT 1 09-25-2011 02:20 PM
Need help with timing cover bolts WhiteCobra94 1979-1995 Mustang GT 33 08-11-2011 02:23 PM
advancing timing 5.slow 1979-1995 Mustang GT 6 08-10-2011 10:40 AM
timing gear drive peoblem? C4king 1979-1995 Mustang GT 8 08-09-2011 08:54 PM
05:35 PM
