Trans fluid - Mustang Evolution
Old 11-22-2011, 02:29 PM   #1
04machazblue's Avatar
Trans fluid
Okay so I have bin doing some research and I need to know what oil to put in my non world calss t5 they say use 50w oil
And one place said 70wgear oil http://www.moderndriveline.com/md_fa...shtml#02136499 this is this website
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 11-22-2011, 06:41 PM   #2
I'm not excatly sureon yours but my 99 model t5 world class uses automatic tranny fluid.
Robbie94gt is offline   Reply With Quote
Old 11-22-2011, 06:46 PM   #3
88fox's Avatar
My t5 also uses auto tranny fluid
88fox is offline   Reply With Quote
Old 11-22-2011, 08:48 PM   #4
Re: Trans fluid
The 70 weight gear oil is correct according to my research.
I would use a synthetic to help the tranny out a bit and to reduce the rotating friction, because they do not use the roller bearings like a WC T5.
Old 11-22-2011, 08:54 PM   #5
I believe that is what I put in mine
Old 11-22-2011, 10:17 PM   #6
Okay Bc I don't have gear oil would that effect shifting ?
Old 11-22-2011, 10:32 PM   #7
Re: Trans fluid
Yes it will.
Gear oil is much thicker than the transmission fluid used in the WC and newer transmissions. So shifting may be a bit heavier feeling, especially when cold.
However, do not substitute thinner oils or auto transmission fluid in its place. They will not properly lube the transmission and it will burn up.
Old 11-22-2011, 11:29 PM   #8
Yes it will.
Okay but my trans isn't a world class trans it's a Borg warner NWC and currently has synchromesh in it, I was thinking I should put the gear oil in
Old 11-23-2011, 12:17 AM   #9
Re: Trans fluid
If it is running synchromesh, it must have been upgraded?
If it was originally designed to use 70W oil and someone changed the oil to the synchromesh fluid, I don't see how it has kept working.
The synchromesh is just to thin and does not have the correct high pressure additives to lubricate a transmission set up for heavy oil.
Old 11-23-2011, 06:46 AM   #10
No it didn't come with synchromesh in it I am not sure what was in it. I know it's a non world class trans number 1352-065 on the Id tag
Old 11-23-2011, 10:42 AM   #11
Re: Trans fluid
Like you said that is a 1984 model NWC T5.
I tried to find a PDF of an owners manual for 1984, but I was unsuccessful.
If I were you I would contact a Ford Dealership and ask them to verify the lubrication needed for your transmission. If you guess wrong it could destroy the transmission.
Old 11-23-2011, 10:45 AM   #12
I called two and they said ATF
Old 11-23-2011, 11:39 AM   #13
Re: Trans fluid
Well, I hope they are correct. My research said gear oil.
I'm just afraid you may have gotten some who were to lazy to look it up and just said ATF because that is what a lot of them do use.
Ask them if they will back that recommendation up with a transmission guarantee?
If it is ATF the Synchromesh is supposed to be one of the best to use.
So you could not tell what was in it originally?
Here's some more info I found. Not sure of the validity, but here it is anyways.
If there is a metal tag on one of the tail housing bolts, look for a number that says "13 52 xxx" the last three digits of the xxx will identify the transmission vintage and gears inside.
If there is no tag, look at the casting number on the main case near the reverse light switch.
If it reads 13-52-065-904 or lower, it is NON-World Class and uses gear oil.
If it reads 13-52-065-908 or higher, it is an 85 or newer T5 and is World Class and uses Dexron-III ATF, or equivalent.
Old 11-23-2011, 01:25 PM   #14
My Id tag on the trans actually says 1352-065 do I guess it is ATF
Old 11-23-2011, 01:43 PM   #15
Las0mbra's Avatar
What're the last 3 numbers? Those don't determine which one it is...
Old 11-23-2011, 01:51 PM   #16
Idk right now I am at work I know those numbers off the top of my head
Old 11-23-2011, 02:45 PM   #17
93slowstang's Avatar
Actually they do. 065 is the last three numbers, means it came out of an 84 mustang/Capri 5.0l. It is pre- world class.
Old 11-23-2011, 05:48 PM   #18
Re: Trans fluid
He means these last three numbers.
« Tail lights | 351 »
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 03:47 PM
Auto trans tune StangSims39 1996-2004 Mustang GT 5 11-12-2011 03:47 PM
Trans Downshift Jolt crkmonzo 1979-1995 Mustang GT 3 08-16-2011 09:35 PM
Best Transmission Fluid Stang23 2005-2010 Mustang GT 0 08-07-2011 01:48 PM
Rear axle fluid Holdempoker102 2005-2010 V6 Mustang 8 07-14-2011 08:56 PM
04:13 AM
