broke bolts for waterpump - Mustang Evolution
Old 11-24-2011, 07:27 AM   #1
I sure some of y'all have ran up on this but 2 of my bolts broke off back in the timing chain cover. And Im running out of options. I went ahead and put it back on and sealed it up real good. Just hope it don't leak.
Robbie94gt is offline   Reply With Quote
Old 11-24-2011, 10:05 AM   #2
If it leaks you may have to take the cover off to get the bolts out.
Old 11-24-2011, 10:48 AM   #3
Re: broke bolts for waterpump
If there is enough bolt sticking out you can weld a nut to the bolt.
The heat from welding will usually help break the bolt loose for easier removal.
Finding WP bolts for the 94-95 is difficult. Search the forums for a thread about WP bolts for the SN95 Mustangs for ideas.
When reinstalling new bolts, be sure to coat the threads with some anti-seize to prevent breakage in the future.
Old 11-24-2011, 12:06 PM   #4
Ok thanks for the info guys. It's almost Been 24 hours since I seal it up so I'm getting ready to start it. But happy thanksgiving to all
Old 11-24-2011, 03:06 PM   #5
Well the water pump Is holding pressure so. I'm glad for thst. But I put a new afpr on it today cuz my pressure was lower than specs. But it's shooting gas out of the vacuum port. So I guessing I bought a bad one. But if my fuel preuusure is about 8 psi below spec do y'all think it would not have all the power that it should have ?
Old 11-24-2011, 04:51 PM   #6
Gas out of the vacuum port means the diaphragm has a hole in it.
Low fuel pressure has a direct effect on how much fuel gets squirted into the engine, so yes, it will also effect how much power the engine is making. Less fuel, less power.
Can I reuse my old Head Bolts? FORDGT14 1996-2004 Mustang GT 8 10-27-2011 05:31 PM
Need locking header bolts! Anyone know where? Benzo 2011-2014 Mustang GT 34 10-26-2011 09:02 AM
Clutch cable broke... Need help... BLUE02GT 1996-2004 Mustang GT 4 09-15-2011 10:36 AM
A/C Compressor Bolts? nickcap 1979-1995 Mustang GT 25 07-21-2011 11:10 AM
broken lower manifold bolts shustwit Pre-2005 V6 Mustang 8 06-29-2011 12:02 PM
08:38 AM
