Question?? - Mustang Evolution
Old 11-24-2011, 09:34 AM   #1
Question??
Right now on my 94 5.0 just my back right tire spins..any way to convert it so both tires spin? And if so how much would that cost??
94GTx306 is offline   Reply With Quote
Old 11-24-2011, 09:48 AM   #2
First of all do u have the 8.8 rearend thsts comes in gts or did somebody put the 7.5 in it. Look at the diff cover. The 8.8 is pretty much even all the way around almost like a square with the corners cut off a little. The 7.5 is smaller is is kinda of a oval shape. Need to know that first of all
Robbie94gt is offline   Reply With Quote
Old 11-24-2011, 09:51 AM   #3
Depending on the one I have does if effect what I wanna do?
Old 11-24-2011, 10:22 AM   #4
deadsp0t's Avatar
You have an 8.8 if it's a GT, if it used to spin both tires then the clutches in the diff may be worn. Don't think all were traction lock though.
That's unimpressive
Old 11-24-2011, 10:29 AM   #5
Yes I have the 94 5.0 GT..so both tires should be spinning?? Bc only one is
---------- Post added at 04:29 PM ---------- Previous post was at 04:25 PM ----------
Well im pretty sure only one spins bc wen I take off my back end swing to the right
Old 11-24-2011, 10:34 AM   #6
93slowstang's Avatar
The swinging to the right is normal for most if not all cars. That's the wheel that catches most of the brunt from the torque and weight shifting.
Old 11-24-2011, 10:39 AM   #7
So both my tires are spinning then...ok I just thought one was
Old 11-24-2011, 10:44 AM   #8
It's not me, it's you.
primer2tone's Avatar
Regardless if you've got worn out posi with a single tire fire or a non-LSD rear end you'll need to replace it. Depending on what type of rear gear you want they can range from $300 to well over $1000. Depending on brand and gearing.
Old 11-24-2011, 10:49 AM   #9
U can tell if both tires spin by looking at your burnout
Old 11-24-2011, 11:09 AM   #10
Im gonna look next time I drive..
Old 11-24-2011, 11:48 AM   #11
Filibuster
Ok well this attatchment is kind of pointless because I was goin to post another pic of my car only spinning one tire I posted it on here a while ago but I cant find it!...
Anywho the clutches in my diff are worn out so if the driver side tire gets alot more traction or the passenger side gets a lot less it will only spin the passenger side blaah!!..
just saying this may be the issue you're having as well!..
XXSTEVEO66 is offline   Reply With Quote
Old 11-24-2011, 11:50 AM   #12
Filibuster
Actually now that im looking at the pic if you see on the right there is a one wheel mark that was left by me another time!...
Old 11-24-2011, 12:14 PM   #13
If my diff is worn out how much to get that repaired?
Old 11-24-2011, 12:17 PM   #14
Filibuster
Old 11-24-2011, 12:18 PM   #15
Opps lol I forgot I was told already lol..
Old 11-24-2011, 12:23 PM   #16
Filibuster
Yeah but the high end of that pricing will include new gears and full install kit..for a basic rebuild assuming everything else is in good condition I would still expect between 3-400 depending again on parts and where you have your work done!..
Old 11-24-2011, 12:29 PM   #17
Ok cool thanks for ur guys help!
Old 11-24-2011, 01:17 PM   #18
Jack the rear end up with Both tires off the ground. First leave it in gear amd try to spin the tire. Neither tire should spin. Second put it in neutral the spin them. Both should spin when u spin one. I have a 94 gt amd when I bought it somebody had change the rear out to 7.5 and only one wheel spin and yours could be like that. By any chance that it is the 7.5 (v6 rearend ) u need to change it with a 8.8
Old 11-24-2011, 01:52 PM   #19
The rear end was never changed..just 373 gears
Old 11-24-2011, 02:06 PM   #20
That is a good idea.it won't tell how it is performing under load but it will tell you if it is working.
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 10:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 01:54 PM
Question for all? NightMare5.0 2011-2014 Mustang GT 61 10-30-2011 10:38 PM
Another Header question OrganDonor 2011-2014 Mustang GT 12 10-30-2011 02:54 PM
Anotger transmission question. Nick_L Classic Mustangs 1 08-24-2011 05:27 AM
12:12 PM
