Clutch stuff - Mustang Evolution
Old 11-25-2011, 04:59 PM   #1
Jnasty9163's Avatar
Clutch stuff
I installed a new clutch put in a new clutch Pedal assembly. everything is installed and now my clutch seems to be slipping on acceleration and I was wondering what's proper techniques for adjustment and if there are any tips or tricks
Jnasty9163 is offline   Reply With Quote
Old 11-25-2011, 05:41 PM   #2
Need some more info .kind of clutch,why you changed clutch.like how did it act before u changed clutch.New transmission?or any other details u have.
Old 11-25-2011, 06:04 PM   #3
Re: Clutch stuff
What did you put in for a new clutch pedal assembly?
Are you using the factory adjustment system or aftermarket?
Factory or aftermarket cable and quadrant?
Old 11-25-2011, 06:41 PM   #4
Jnasty9163's Avatar
Clutch was old and wore out, 1990 pedal assembly because clutch was out of adjustment so tight that it stripped the shaft that the quadrant is connected to. Using steeds firewall and quadrant. I have it shifting well, but if I accelerate even a little hard it slips. I'm thinking maybe it's just a little disengage by my rookie adjustment is too close to disengaging the clutch
Old 11-25-2011, 06:49 PM   #5
Re: Clutch stuff
I'd say you have it set to tight. You need to adjust for a bit of freeplay to ensure the pressure plate is able to apply full clamping force.
Old 11-25-2011, 06:56 PM   #6
+1 you should have about 1/2" - 1" of slop in the top of the pedal
Old 11-25-2011, 07:00 PM   #7
Jnasty9163's Avatar
Alright thanks guys I'll check it out tomorrow. Hop y'all had a good thanksgiving
Old 11-26-2011, 06:59 AM   #8
Jnasty9163's Avatar
Also, is it possible to stretch the cable from it being too right?
Old 11-26-2011, 07:07 AM   #9
Yes very possible.also possible to bend clutch fork.
Old 11-26-2011, 03:15 PM   #10
Re: Clutch stuff
pull up on clutch petal and it release the pressure the clutch should in simple form adjust it self but never had luck with that had to adjust manual by hand
kid_kash_00 is offline   Reply With Quote
Old 11-26-2011, 04:37 PM   #11
He said he has firewall adjuster.
Old 11-29-2011, 09:28 AM   #12
Re: Clutch stuff
me to but still have auto adjust under dash its plastic unless replaced already
New guy with a clutch question Cajunick 1996-2004 Mustang GT 7 11-15-2011 11:32 AM
Clutch eouellette18 2005-2010 Mustang GT 9 09-08-2011 03:51 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
Spec or ram clutch 04machazblue 1996-2004 Mustang GT 3 08-23-2011 04:36 PM
Need advise on a new clutch j4gwig General Mustang Discussion 1 08-01-2011 07:51 PM
03:01 PM
