Throw out bearing question - Mustang Evolution
Old 11-25-2011, 08:40 PM   #1
jhagan1980's Avatar
Does the TOB ride against the fingers on the pressure plate at all times? I look through the clutch cable adjustment cover and the bearing is against the fingers.
jhagan1980 is offline   Reply With Quote
Old 11-26-2011, 07:49 AM   #2
jhagan1980's Avatar
Anybody?
Old 11-26-2011, 07:56 AM   #3
deadsp0t's Avatar
It should be in the end of the shift fork, and move when the fork moves
That's unimpressive
Old 11-26-2011, 08:33 AM   #4
jhagan1980's Avatar
It is but the face of the TOB is constantly in contact with the pressure plate fingers. Is this normal since its a cable type system?
Old 11-26-2011, 09:46 AM   #5
deadsp0t's Avatar
Not sure honestly, how is the clutch feel/adjusted?
That's unimpressive
Old 11-26-2011, 10:14 AM   #6
Filibuster
I believe it sounds fine what you're saying...im sure your clutch is hydraulic but its probably very similar to mine (minus the slave cylinder) and the TOB sits in the clutch fork with alot of room to mess with so I dont see any prob if it touches the clutch forks as long as your clutch is adjusted properly...IMO im not a rocket scientist..
XXSTEVEO66 is offline   Reply With Quote
Old 11-26-2011, 10:43 AM   #7
deadsp0t's Avatar
He has a 95 cobra so it's just like yours.
That's unimpressive
Old 11-26-2011, 10:46 AM   #8
Filibuster
Sooo a 95 is still fully manual?..no hydraulic huh?...id have thought ford would've changed that by 95??..
Old 11-26-2011, 10:47 AM   #9
Re: Throw out bearing question
No, it should not constantly contact the pressure plate fingers.
If it does then you will quickly wear out the bearing and/or fingers.
Old 11-26-2011, 10:54 AM   #10
Filibuster
Zang....TH has spoken!...*bows to sensei* your right!...
Old 11-26-2011, 11:23 AM   #11
Ahh! Tank you for confirmation Grasshopper!
Name:	Clutch Works.png
Old 11-26-2011, 11:31 AM   #12
jhagan1980's Avatar
The pivot ball is at the top of the bellhousing and the clutch cable is on the bottom. So to keep tension on the cable it would have to keep contact on the fingers. So what am I to do.
Old 11-26-2011, 11:46 AM   #13
Filibuster
Your setup is the same as mine the pic TH showed is not of our setup just of whats goin on with the TOB...
Im not sure your exact problem,but the clutch fork will ”flop” around if the cable isn't connected..not exactly sure what it rests against but...man I might have to go take some pics..i dont have the dust cover over the fork so I may be able to get an inside pic..
Old 11-26-2011, 11:49 AM   #14
Here's the "cure".
See the Word doc attached.
File Type: doc Clutch freeplay correction kit directions.doc (235.5 KB, 922 views)
Old 11-26-2011, 02:23 PM   #15
jhagan1980's Avatar
Here's the "cure".
Not seeing anything. I'm on my iPhone.
Old 11-26-2011, 02:30 PM   #16
Clutch Freeplay Correction Kit
Old 11-26-2011, 02:45 PM   #17
jhagan1980's Avatar
How does that work? Just keeps tension on the fork pushing it back? Where does it install at? Sorry for all the noob questions but this is the first time I've ever worked on a transmission.
Old 11-26-2011, 03:11 PM   #18
i have a 94 it rides against pressure plate 24/7
kid_kash_00 is offline   Reply With Quote
Old 11-26-2011, 07:02 PM   #19
It goes between the clutch fork and the bellhousing cable guide.
It allows you to properly adjust your clutch so the TB does not ride on the forks by keeping the slack out of the cable.
Old 11-26-2011, 07:03 PM   #20
Then it s not properly adjusted and eventually the TB will overheat and seize up.
Old 11-26-2011, 07:32 PM   #21
jhagan1980's Avatar
I'm not sure that is made for my year. Apparently that website makes nothing for the 94&95 mustang.
Old 11-26-2011, 07:41 PM   #22
It should work. If it fits the 86-93, then it should work on a 94-95.
When you get to a PC, look at the Word document. Then it will make more sense and you can check your car to see if it is the same, which I am sure it is.
You could go to a hardware store and buy a spring and cpvc plastic pipe bushing and make your own too.
Old 11-26-2011, 10:14 PM   #23
jhagan1980's Avatar
This will stiffen the pedal as well as fix the tob problem right?
Old 11-27-2011, 01:16 AM   #24
Yes, that is what it is supposed to do.
It takes up the slack so you can adjust the clutch to where the TOB does not ride on the pressure plate fingers.
Old 11-27-2011, 06:31 AM   #25
am about to try these setup next week I will post pics, but here is one I found on the webb
robertoortiz85 is offline   Reply With Quote
Old 11-27-2011, 02:44 PM   #26
That's it or a variation of it anyways.
Let us know how it works out.
Old 11-27-2011, 03:20 PM   #27
deadsp0t's Avatar
I always had my clutches adjusted where they were fully engaged with the pedal barely off the floor, I do the same thing with my bike. With a street bike I know this is the preferred set up for spirited riding.
That's unimpressive
Old 11-27-2011, 03:34 PM   #28
I keep mine adjusted to where the TOB isn't contacting the pressure plate fingers and adapt my left foot to wherever the pedal ends up.
It works for me, as the same clutch, pressure plate and TOB have been in my car for the last 10+ years.
I can deal with a less than ideal clutch pedal position much easier than replacing the clutch components more often.
Old 11-27-2011, 03:39 PM   #29
deadsp0t's Avatar
I honestly never looked at it(TOB). Guy put clutches in my cars for $150 and got it back the next day with the pedal adjusted the way I liked it. My King Cobras never lasted that long, was on my 2nd one in year 5 or 6. Lol that car saw 5k everyday, sometimes twice!
That's unimpressive
Old 11-27-2011, 03:43 PM   #30
Whatever works for each owner.
I don't let anyone else touch my car other than my cousin. Between the two of us anything that needs to be done, one or the other of us can do it.
Just one of my many little idiosyncrasies.
Old 11-27-2011, 03:50 PM   #31
deadsp0t's Avatar
He closed up shop to go to work for Porsche, and ended up opening a bar and won't turn a wrench at all lol can't say as I blame him though!
That's unimpressive
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 09:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 12:54 PM
short throw shorter.. fordgirl1209 Pre-2005 V6 Mustang 11 08-23-2011 04:23 AM
Throw Out Bearing? USAF_stang 1996-2004 Mustang GT 9 07-20-2011 01:07 PM
WTB/ short throw shifter 93stang306 Mustang Parts for Sale and Wanted 0 06-25-2011 08:10 PM
02:53 PM
