Thermostat Housing - Mustang Evolution
Old 11-27-2011, 06:21 PM   #1
Tj88mustang's Avatar
Thermostat Housing
Does anyone have an issue with the thermostat housing and the housing flange on the 302 intake not totally matching up I can't get it to totally seal. I've even tried to make another gasket to the housing and it didn't work. It looks like the bypass tube over hangs the flange on the intake just a pinch It leaks at that corner. I've tried rtv also. Any thoughts?
Also have an opportunity to get a 97 explorer upper and lower intake. 97 explorer IIRC. It's the type with the EGR passages. No porting or repairs,no stripped bolt holes. Some minor pitting on the throttle body flange,but nothing that will present a problem.
Do you guys know if this will work on my car I have a 88 gt
Tj88mustang is offline   Reply With Quote
Old 11-27-2011, 06:54 PM   #2
It may be a cheap aftermarket one.they sell them at AutoZone.did u double check to make sure The thermostat is in the right direction?just some thoughts.
Old 11-27-2011, 07:06 PM   #3
aegischief's Avatar
If you car is a California car or has been converted to mass air, the intake will work.
aegischief is offline   Reply With Quote
Old 11-27-2011, 07:14 PM   #4
@dreamstang lol yes it is. It is an aftermarket one. One i got from mishimoto with the radiator kit the other one I got from advanced auto they're both identical. should I go to ford and order one? Or will the aftermarket one line up with the explorer lower intake?
Old 11-27-2011, 07:22 PM   #5
Both housings leak?[COLOR="Silver"]
I would suggest getting a new one.take yours with u so u can compare them before u but them.
Old 11-27-2011, 07:30 PM   #6
Yes both leaked at the same corner. The gasket matches the intake flange But not the housing flange exactly.
---------- Post added at 12:30 AM ---------- Previous post was at 12:30 AM ----------
From ford?
Old 11-27-2011, 07:37 PM   #7
From ford?
That is weird!yes it would be best to get from ford at this point.I don't personally like to buy dealer parts unless I have to cause the price.but sometimes there is no choice.compare it to your other ones before you install it so if its not different u can take it back without wasting money.
Old 11-27-2011, 08:30 PM   #8
I'll go by tomorrow and see thanks for the advice
Old 11-27-2011, 08:38 PM   #9
No problem.
black headlights housing 82stang224 1979-1995 Mustang GT 7 09-20-2011 02:54 PM
T-Max Transmission Thermostat Trojan Horse 1979-1995 Mustang GT 3 08-27-2011 03:35 AM
HID in reflector housing mickeyp49 2011-2014 V6 Mustang 14 07-21-2011 01:49 PM
01:13 AM
