Burnt wires - Mustang Evolution
Old 11-29-2011, 10:57 PM   #1
93slowstang's Avatar
Burnt wires
Went to go to the store a few minutes ago and a wire to my lights decided it was time to go. Luckily the damage is minimal, but I don't know if it burnt any wires in the harness yet. Hopefully the cause of it was only related to that one.
Old 11-30-2011, 01:38 AM   #2
Re: Burnt wires
That's not good.
Make sure the wire isn't shorted and over amping.
Old 11-30-2011, 02:38 AM   #3
deadsp0t's Avatar
Sucks man! Glad to hear there was only minimal damage, I know you are.
That's unimpressive
Old 11-30-2011, 02:45 AM   #4
Originally Posted by Trojan Horse
That's not good.
I know it's the power wire for the parking lamps and instrument lighting that burnt up. Jumped all the connections to make sure it wasn't the switch and found out my parking lights are shorted somewhere.
I think I may have pinched a wire somewhere under the dash, but won't know till tomorrow when I pull it out.
---------- Post added at 03:45 AM ---------- Previous post was at 03:44 AM ----------
It was only that one wire thank goodness, I'm going to try and run a new one tomorrow while I search for the short.
Old 11-30-2011, 04:11 AM   #5
That sux .I'm sure you'll get her fixed up in no time.good luck.
Old 11-30-2011, 06:38 AM   #6
Thanks, I'm sure going to try. May have to toggle the lights in the back temporarily until I can do it properly. Work schedule sucks this week.
Old 11-30-2011, 08:50 AM   #7
Well narrowed it down to the front corners, couldn't find where it's shorting at though.
Old 11-30-2011, 11:58 AM   #8
Re: Burnt wires
hey i notice your parking lights and blinkers are backwards the middle ones are suppose be blinkers and the sides are the running lights thats how my fox was man and i saw yours was the opposite might wanna see if it matters
kid_kash_00 is offline   Reply With Quote
Old 11-30-2011, 01:57 PM   #9
Re: Burnt wires
Been thinking about this, Why didn't the fuse blow instead of the wire burning up?
kid_kash_00, The outer lights are supposed to be the turn signals. They put them on the corners for increased visability.
Old 11-30-2011, 04:34 PM   #10
Re: Burnt wires
might have had a bigger fuse than suppose to mine burnt the wires when i hooked the fog lights up to much load on old wires maybe my fox was backwards lol
Old 11-30-2011, 05:12 PM   #11
Re: Burnt wires
That's another possibility. In older cars that use the 1/4" diameter fuses I have seen people actually put a piece of 1/4" od copper tubing in place of a fuse and I read about the infamous .22 caliber bullet fuse replacement which supposedly went off and shot the driver in the leg.
If your car is using the inner lights for the turn signals, I am surprised it passed inspection. In an accident that could work against you. I'd see about changing that were I you.
Old 11-30-2011, 05:55 PM   #12
deadsp0t's Avatar
I've had 4 Fords, 2 95 GT's, 2 T-birds that all used the same headlight switch and all four failed and had different symptoms. Hell my 91 V6 T-bird the dimmer switch would actually dim out the rear taillights. This or something related could be the issue with the funny turn signals, and possibly something to do with slowstang's issue as well.
That's unimpressive
Old 11-30-2011, 06:26 PM   #13
The one that blew was too small so I didn't think too much about it. Put the proper size in and it started smoking and burnt the wire up. I've seen a lot of similar threads looking for the diagram so I'm guessing its not too rare for that one to burn up.
---------- Post added at 07:26 PM ---------- Previous post was at 07:24 PM ----------
Oh and my turn signals do still work and are on the outside. They've never come on with the parking lights since I've had the car so it's no bother to me now that the wire is cut.
Old 11-30-2011, 06:31 PM   #14
Angry Re: Burnt wires
thats our luck we try upgrade then have to fix more stuff
Old 11-30-2011, 07:32 PM   #15
Re: Burnt wires
So the wire you burned up is to the headlights?
What about the fog lights or do you have them?
I remember that the switch and maybe the wiring too, was insufficient to power both from the factory.
Old 11-30-2011, 07:46 PM   #16
No it was to the parking lights, the headlights are fine. I already rewired the fog lights and put them on their own fuse. I used the headlight power wire to jump out the others to check for the shorted wire.
Old 11-30-2011, 07:49 PM   #17
Ilovemustangs88's Avatar
Good luck I hope you have an easy fix!
Ilovemustangs88 is offline   Reply With Quote
restore yellow burnt headlights cheap 1988_gt_5.0 General Mustang Discussion 10 10-15-2011 03:24 AM
Plugs and Wires input needed? tbonestang 1979-1995 Mustang GT 7 08-02-2011 03:39 PM
06:46 AM
