Trick flow opinions - Mustang Evolution
Old 12-02-2011, 03:17 AM   #1
Tj88mustang's Avatar
Trick flow opinions
Getting ready to order Trick Flow Box R series upper and lower intake opinions needed and greatly appreciated. I am planning forced induction on this motor...
Tj88mustang is offline   Reply With Quote
Old 12-02-2011, 06:44 AM   #2
93redfox's Avatar
What size engine are you running and what rpm are you wanting to spin it to?
93redfox is offline   Reply With Quote
Old 12-02-2011, 10:51 AM   #3
Re: Trick flow opinions
With forced induction it will work fine, without forced induction it will kill your bottom end power.
Old 12-02-2011, 09:42 PM   #4
aegischief's Avatar
That intake doesn't really start to make power until 4000 rpm's. If you wanna keep the motor wound up, go with it. If you due plan on putting some forced induction on it, that intake will work fine.
aegischief is offline   Reply With Quote
Old 12-03-2011, 04:22 AM   #5
Thanks everyone for your input I don't know if this is the way I'm going to go. Apparently there are some clearance issues with the hood and distributor, so still trying to decide.
Old 12-03-2011, 12:24 PM   #6
I ran across an article some time back saying the Holley Systemax intake works pretty good for a forced induction engine. You might want to check it out.
Old 12-03-2011, 01:03 PM   #7
93redfox's Avatar
I have the Holley Systemax on my NA 306 and love it! It pulls strong all the way to the stock rev limiter. I need to remove the limiter and it should pull to 6500 possibly more with my Anderson cam. It is one of the best if not the best long runner style intake for 6500-6700 rpm. It's only competitor is the Edelbrock rpm II which is almost dead even with it. Both will work great for boost.
Old 12-03-2011, 01:31 PM   #8
I guess I'm looking for something that would give me enough low end to help turbo lag but still have enough flow to work with the turbo maybe a smaller trick flow? Or elderbrock I'm not building a drag car
---------- Post added at 06:31 PM ---------- Previous post was at 06:24 PM ----------
@redfox that's what I was looking for thanks for the advice I'll look into them both.
Old 12-03-2011, 01:35 PM   #9
Just use whatever intake you want then.
With the new TC systems lag is not the problem it once was.
The Holley Systemax, Edelbrock RPM II or any of the Trick Flow intakes will work just fine for your purposes.
P.S. I'm starting out my supercharged build with a ported Cobra intake (How's that for low buck? ). I'll see how well it does and upgrade from there if I'm not satisfied.
Old 12-03-2011, 02:33 PM   #10
Lol I just don't want to buy twice.
Old 12-03-2011, 03:00 PM   #11
93redfox's Avatar
Trick flow track and street heat will work well too its not as big of a deal with forced induction. You could run one of the older edelbrock rpm manifolds too
Old 12-04-2011, 02:46 PM   #12
I don't blame you for that. The cost of the intakes for these engines are ridiculous anyways IMO.
Given my choice I would probaby go with the Sytemax first, the Edelbrock RPM II second and one of the Trick Flow intakes 3rd.
No particular reason for that order, other than I think the Systemax is the best 1st choice and I like the looks of the RPM II over the Trick Flows.
Upgrade indecision... Need opinions wc3john 1979-1995 Mustang GT 10 11-06-2011 02:29 PM
Trick flow top end kit Jesse Bach General Mustang Discussion 4 10-12-2011 07:45 AM
Trick Flow 1.6 rocker arms for sale!! WhiteCobra94 Mustang Parts for Sale and Wanted 1 08-09-2011 09:05 AM
I need some opinions. 98RedGT 1996-2004 Mustang GT 3 07-26-2011 04:03 PM
opinions on color for 88 fox 04TRV6 1979-1995 Mustang GT 39 07-08-2011 12:30 AM
04:28 AM
