92 gt 8.8 - Page 2 - Mustang Evolution
Old 12-08-2011, 05:48 AM   #36
93stang's Avatar
Ok so am I dpropin all the fluid out of the rear? Do I just take the diff cover of or just loosin it up so it will drain?
93stang is offline   Reply With Quote
Old 12-08-2011, 06:22 AM   #37
93slowstang's Avatar
Originally Posted by aegischief
It will work without friction modifier, even with regular off the shelf oil. You need friction modifier in ford differentials in order for them to work correctly and lockup like it should.
On the bottle it states that it already contains the friction modifier and adding it was not necessary.
Old 12-08-2011, 07:36 AM   #38
So what happens if it doesn't have any friction modifer in it. I did my a lil ago and didn't put none in it. Didn't know to. But the traction lok don't seem to work properly. It's hard to tell cuz I have wheelhop realbad cuz I don't have the quad shocks on yet
Robbie94gt is offline   Reply With Quote
Old 12-08-2011, 09:01 AM   #39
93redfox's Avatar
Without friction modifier your clutches will chatter when you make turns and will probably wear them out prematurely.
93redfox is offline   Reply With Quote
Old 12-08-2011, 09:54 AM   #40
Re: 92 gt 8.8
Loosen it up and let it drain.
Then you should remove the cover and replace the gasket so you won't possibly develop a leak later.
Old 12-08-2011, 10:00 AM   #41
Re: 92 gt 8.8
Replace your factory upper and lower control arms with some good aftermarket units and you won't need the quad shocks.
Old 12-08-2011, 10:29 AM   #42
Ok thanks troganhorse
Old 12-08-2011, 10:38 AM   #43
Oic
Will Stock 1998 GT H-Pipe Fit My 2003 GT? Brent 1996-2004 Mustang GT 5 10-12-2011 08:44 PM
Sn95 8.8 in my 85 GT Klinton 1979-1995 Mustang GT 21 09-13-2011 04:47 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
08:32 AM
