exhaust - Mustang Evolution
Old 12-05-2011, 01:55 PM   #1
351mustanggt's Avatar
exhaust
i am lookin at buying a midpipe and was wondering what the difference in sound between a o/r h pipe and a high flow catted h pipe ? also for the o/r would there be anything different in the install?
351mustanggt is offline   Reply With Quote
Old 12-05-2011, 02:23 PM   #2
Re: exhaust
The O/R pipe will be louder and flow more without the restriction of the catalytic convertors.
For the O/R install, if it does not have provisions for your smog pump tube, you will have to disable the pump or completely remove the system.
If you do that, make sure you can still get it inspected as your local inspection laws my not allow its removal.
Old 12-05-2011, 02:38 PM   #3
thanks, didnt even think about the smog pump
Old 12-05-2011, 05:43 PM   #4
89 Foxloco's Avatar
Whats the hp gain in straight pipe?? With shorties..
89 Foxloco is offline   Reply With Quote
Old 12-05-2011, 05:58 PM   #5
lateralzero's Avatar
Region: Iowa
Re: exhaust
I have an off road x-pipe on my mustang and it has the smog pump tube. So before you go eliminating stuff you might want to check some different models of h-pipes. Im sure if they put it on the x pipe theyll have h pipes with them too.
lateralzero is offline   Reply With Quote
Old 12-05-2011, 06:04 PM   #6
even if it is setup for smog he will still have no cats.if he has to get emmision tests then he will need cats.but the plus of that is he can change the pipes out for inspection and not have to worry about smog.
Old 12-05-2011, 06:07 PM   #7
im planning on keepin my oem h pipe and swappin it on for inspections bc even the catted ones arent inspection acceptable because it doesnt have 4 cats
Old 12-05-2011, 06:20 PM   #8
then it would be a good idea to keep the smog also.you can get a pipe without and weld a bung in to connect the smog to.or find one that accepts smog.
---------- Post added at 07:20 PM ---------- Previous post was at 07:19 PM ----------
do they actually count the cats?
Old 12-05-2011, 06:40 PM   #9
according to my mechanic that ive had for years if their book says 4 cats is oem and you have 2 you fail
---------- Post added at 08:40 PM ---------- Previous post was at 08:35 PM ----------
i dont know if hes just giving me the legal version but he told me just keep the oem and swap em the day of the inspection
Old 12-05-2011, 06:46 PM   #10
Makes sense.I guess I never really saw them count on my inspections.its usually just a real quick look.
Old 12-05-2011, 06:57 PM   #11
kinda odd to me since all aftermarket have two but yet most of em say dot approved
exhaust
Different exhaust on v6 with PP? 2012Stang4Me 2011-2014 V6 Mustang 5 11-02-2011 09:05 AM
exhaust question... (04 GT) Topless04GT 1996-2004 Mustang GT 7 07-23-2011 04:10 PM
Will an exhaust from a 2010 mustang work on a 1968 LeviG2010 General Mustang Discussion 3 07-09-2011 07:22 AM
Doesnt like these exhaust Blackedout Pre-2005 V6 Mustang 40 06-30-2011 08:50 PM
11:57 AM
