Tranny noise - Mustang Evolution
Old 12-05-2011, 09:44 PM   #1
Elfman's Avatar
Tranny noise
Hey guys. I just got my first car. Its an 83 5.0. I put a different 302 in it and a tremec 5 speed from a 88 gt in the car. The car i got the trans from had been rolled 3 times. Anyways, as soon as i put the car into 3rd gear, i heard a whine/howl that sounds like its coming from the trans. Does anyone have any ideas what it could be and how to fix it on a low high school budget!
Elfman is offline   Reply With Quote
Old 12-05-2011, 09:47 PM   #2
deadsp0t's Avatar
First check the fluid level, if you've already changed it did you use synchromesh fluid?
That's unimpressive
Old 12-05-2011, 09:56 PM   #3
Elfman's Avatar
Its full on fluid and no i dont think so..? I just ordered the tranny fluid that the local parts store suggested to me and put it in
---------- Post added at 08:56 PM ---------- Previous post was at 08:53 PM ----------
And its a bit of a pain to get it into reverse. Is the reverse thing normal with tremec's?
Old 12-05-2011, 10:11 PM   #4
deadsp0t's Avatar
Pretty sure they call for synchromesh, it's made by GM. My Tremec 3550 called for that. They are much more mechanical feeling V. a T5.
That's unimpressive
Old 12-05-2011, 10:17 PM   #5
Elfman's Avatar
Alright thank you very much. Got an estimated price on that?
Old 12-05-2011, 10:19 PM   #6
deadsp0t's Avatar
$10-$11 dollars a quart I think.
That's unimpressive
Old 12-05-2011, 10:20 PM   #7
Elfman's Avatar
Ok sounds good. Im gonna try it within the next few days. If it doesnt work then i will let you know
Old 12-06-2011, 01:17 AM   #8
Elfman's Avatar
Anyone else got anymore ideas?
Old 12-06-2011, 07:51 AM   #9
93redfox's Avatar
Sounds like it could be a bearing and with the reverse problem try putting it into second and then reverse and it sometimes it will go in easier
93redfox is offline   Reply With Quote
Old 12-06-2011, 08:38 AM   #10
jwhayne0001's Avatar
Got an aftermarket shifter? I put a pro50 on my t5 and 3rd whines like a super charger and from what I read it's normal
jwhayne0001 is offline   Reply With Quote
Old 12-06-2011, 08:40 AM   #11
93slowstang's Avatar
Not synchromesh, the t5 calls for dex/merc AT fluid. I got a warning label with mine that use of synchromesh would cause damage and void the warranty.
Old 12-06-2011, 09:07 AM   #12
Elfman's Avatar
Ya it has a short throw shifter in. And im running the ATF so...
Old 12-06-2011, 09:45 AM   #13
deadsp0t's Avatar
Oh wow that's good to know! Thanks!
That's unimpressive
Old 12-06-2011, 09:58 AM   #14
I have a steeda tri-ax in mine. It whines in first and second.
Old 12-06-2011, 10:58 AM   #15
Kyle94GT302's Avatar
I have a rebuilt t5z out of a 95 cobra and pro 5.0 short throw and use valvoline max-life ATF fluid and I don't have any issues or whine in any gear!!
98 GT- Full PI swap, 93 tune, 3:73 gears,off-road h-pipe,flows, ported plenum and spacer, mac cai, lowered on eibach springs and eibach shocks and struts,spec stage 2 clutch, pro 5.0 shifter
94gt-H,C,I exhaust, eibach suspension--SOLD
Kyle94GT302 is offline   Reply With Quote
Old 12-06-2011, 11:01 AM   #16
Elfman's Avatar
Ya but thats a newer transmission. Possibly tremec made some upgrades to prevent the whine with a short throw shifter?
Old 12-06-2011, 11:21 AM   #17
That's true and my Trans doesn't have many miles on it and I put hardened gears and stronger synchros in it! I would agree with previous suggestions change the Trans fluid and see if that helps
Old 12-06-2011, 11:39 AM   #18
Elfman's Avatar
Ive also heard from my dad that it could possibly be my syncros? Is that a possibility?
Old 12-06-2011, 06:30 PM   #19
93redfox's Avatar
If it whines in gear then it is not your synchros. Synchronizers are only used when shifting from gear to gear. If it shifts up and down through the gears smoothly your synchros are fine. If you have difficulty shifting from gear to gear or have grinding issues then you may have a bad synchro or bent shift fork.
---------- Post added at 08:30 PM ---------- Previous post was at 08:28 PM ----------
About shifting problems it could also be that your clutch may not be disengaging all the way
Old 12-06-2011, 06:34 PM   #20
Elfman's Avatar
Oh ok well thank you very much!!
Old 12-06-2011, 06:47 PM   #21
93redfox's Avatar
None of what I spoke of above will cause a whine while in gear though. A whine has to do with a bearing, a gear meshing problem or under filled transmission. Remember a light whine can be a normal condition but it shouldn't get louder with higher rpm, and wrong fluid shouldn't cause a whine. It will just affect the friction properties of the synchronizers. Certain fluids have diff additives that affect friction of metal on metal. Some metals are made to grab one another while submerged in fluid (brass synchros also known as blocking rings) and others just need to stay lubricated (gears and bearings).
Old 12-09-2011, 02:28 PM   #22
The only whine in mine is that nag that sometimes goes for ride with me
tbonestang is offline   Reply With Quote
Old 12-09-2011, 04:01 PM   #23
That just made my day, lol.
Old 12-09-2011, 04:36 PM   #24
JetLife 01GT's Avatar
I have that same problem tbone... Lmfao
In my 01, I get a whine that gets louder as the rpms go up. Starts whining at about 1700-18 rpm in first gear. That's the only gear and also I don't have the t5. So I dnt think I'm any help at all lol
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 12-09-2011, 06:30 PM   #25
93redfox's Avatar
First gear its common to have a whine just nothing crazy
Old 12-09-2011, 06:58 PM   #26
Really one does it really only in 1 and 2 when I get on it real hard
Old 12-09-2011, 08:47 PM   #27
93redfox's Avatar
That's interesting, it's probably normal. I have the same light whine in first and second when slowly accelerating but not
under hard acceleration. Then again I am running a tremec 3550 so it's apples to oranges. My thoughts are that the main shaft is spinning so slow in first and second that it is easier to hear the gears meshing under the high torque load of the lower gears. Just a guess really but there is logic to it
When I put gas pedal, wind noise!! jmpark527 2005-2010 Mustang GT 28 11-23-2011 09:45 AM
Nasty noise under the hood please help! S197STANG 2005-2010 Mustang GT 18 11-05-2011 10:14 PM
Clutch noise 02 mustang gt mkw037 1996-2004 Mustang GT 5 09-05-2011 08:14 AM
Noise help! Dnraiders 1996-2004 Mustang GT 3 08-23-2011 07:15 AM
11:09 AM
