Good cam - Mustang Evolution
Old 12-06-2011, 12:05 PM   #1
Good cam
It's a quick survey
What cam would u use with a stock heads gt40 intake and explorer injectors
tbonestang is offline   Reply With Quote
Old 12-06-2011, 12:20 PM   #2
Army_Stang's Avatar
Re: Good cam
this is a good question, i was wondering the same thing....i might be picking up a f303 cam for cheap and from what couple guys have told me its a good cam to run with the intake change
--There are some who've forgotten why we have a military. It's not to promote war; it's to be prepared for peace. -- Ronald Reagan
--We're in a war, dammit! We're going to have to offend somebody!" -- John Adams
Army_Stang is offline   Reply With Quote
Old 12-06-2011, 12:40 PM   #3
But I think that's good for a auto I believe
Old 12-06-2011, 01:26 PM   #4
93slowstang's Avatar
F cam if you are going FI, b cam if na, or e cam if your unsure. The f cam is more of a mild forced induction cam.
Old 12-06-2011, 01:36 PM   #5
Army_Stang's Avatar
Re: Good cam
okay so since im not going forced induction anytime soon i should get it yet?
Old 12-06-2011, 02:11 PM   #6
No fi for me so I'm guessing b or a similar one. How are the summit cams
Old 12-06-2011, 03:28 PM   #7
I don't know how good the summit cams are, I went with an e303 and love it.
Old 12-06-2011, 03:42 PM   #8
mystang50's Avatar
Re: Good cam
go e cam!!
Old 12-06-2011, 05:38 PM   #9
93redfox's Avatar
The trick flow stage 1 is a good choice and will make good power still if you have future upgrades in mind. It is cheaper than the ford alphabet cams, at least at summit anyway
93redfox is offline   Reply With Quote
Old 12-06-2011, 06:55 PM   #10
Forgot to say I have a 95 s
5spd turtle but sound like a bear
Old 12-06-2011, 07:04 PM   #11
Makes your cam choice easier to pick.
Old 12-06-2011, 08:13 PM   #12
Filibuster
I personally haven't looked into cams much yet....BUT!...just thinkin the old ”alphabet” cams may be a little out dated..thinking you might find something better from comp cams,lunati,crane cams or something....again this is just my opinion thinking with newer technology there could be better cams for the fox's out there!..
XXSTEVEO66 is offline   Reply With Quote
Old 12-06-2011, 10:29 PM   #13
04machazblue's Avatar
Go with the e cam sounds good and makes good mid range power i get complements all the time if. Cam works great with my heads and intake my car pulls really hard. Do u plan on doing any other types of mods
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-06-2011, 10:48 PM   #14
93redfox's Avatar
I run an Anderson cam, they are getting on the pricey side and I'm not sure if they make a cam for a stock head setup but it can't hurt to call Rick at Anderson Ford Motorsport and pick his brain. He gave his recommendation to me and I am running the N61 now with no regrets trapping 115 to 116 with an NA 306 and trick flow heads that I ported daily driven.
Old 12-06-2011, 10:48 PM   #15
Jkgravy's Avatar
E cam with that set up you will like it... And as for them being out dated... Why change something that works and works well?
Jkgravy is offline   Reply With Quote
Old 12-07-2011, 12:30 AM   #16
Re: Good cam
Cam selection tool - CamQuest
Let the people who make them help you choose what's right for your combination.
No offense intended to anyone's suggestions guys, but cam choice is better left to the experts.
I learned this the hard way and ended up spending a lot of time and money to make one of my first cars slower than it was originally.
Old 12-07-2011, 12:48 AM   #17
WhiteCobra94's Avatar
It's a quick survey
The best cam with stock heads is the stock cam, but if you can find steeda #19 but most likely they'll will be used
---------- Post added at 01:48 AM ---------- Previous post was at 01:46 AM ----------
Also if your swapping cams just remember depending on your mileage you might want to check your heads and your bearings and rings
Old 12-07-2011, 12:58 AM   #18
93stang's Avatar
I agree let the experts give u a few choices and u puck from them. As far as ford racing cams go and being outdated cause of new technology we drive Foxbodies ok the new technology is going to the newer cars. Hell ford racing is not even making cams for the Foxbodies anymore.
93stang is offline   Reply With Quote
Old 12-07-2011, 06:55 AM   #19
93redfox's Avatar
Getting an expert's opinion is the way to go just as I stated earlier in the thread. I talked to Anderson Ford who designs and tests there own cams to a high degree and Rick Anderson gave me his suggestion and he would do the same for you. There are also other cam designers too such as Camshaft Innovations, FTI, and Cam Motion are just a few that come to mind but these are mostly custom grind cams which get pricey. It might not be cost effective for a stock head setup. Camshaft technology has come a long way since the alphabet cams but yes there is power to be had by using them.
Old 12-07-2011, 12:42 PM   #20
Not looking for a custom grind and not willing to drop a grand on new heads. Just want something more then grandma car. If u own a sn95 u know what I mean . My old ladies grocery getter has better pickup. Not looking to build a drag car but a bit tired of the 3 yr old beating meto the corner and he's on a big wheel. Now I have driven a bone stock 95 and mine is a bit quicker but this is a mustang not a 89 coupe Seville
Old 12-07-2011, 01:02 PM   #21
What does your car have now, gears, exhaust .....?
Old 12-07-2011, 02:45 PM   #22
Cai h pipe bbk headers flowmaster muff stock rear sct tuner and 97 explorer injectors ac del and under pulley
Old 12-07-2011, 02:53 PM   #23
Re: Good cam
Get 4.10 gears and re-tune shift points if auto trans.
Best bang for the buck and seat of the pants improvement.
Old 12-07-2011, 02:55 PM   #24
5 spd and the rears has less then 500 on it from last owner . Don't know why he didn't
Old 12-07-2011, 03:27 PM   #25
Re: Good cam
If it doesn't have gears I would sure put them on the list anyways.
You'll get a lot better acceleration with them than a cam change can provide.
Old 12-07-2011, 03:42 PM   #26
With 5-speed I'd go with 3.73 , I have 4.10s in mine with stock motor and it was a complete night and day difference
cam gear spacer duffeycycles Classic Mustangs 2 12-03-2011 08:45 PM
Rebuilt aoed, cam question Schlahty 1996-2004 Mustang GT 0 11-10-2011 02:11 PM
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
Cam gears 2001mustang Pre-2005 V6 Mustang 8 10-16-2011 08:16 PM
Good looking 18s? TommyTsunami88 General Car Discussion 4 09-13-2011 04:45 AM
06:11 PM
