Torque Converter ? - Mustang Evolution
Old 12-07-2011, 12:41 AM   #1
WhiteCobra94's Avatar
Torque Converter ?
Ok I'm gonna be ordering my torque converter soon and I need a 2500 stall lock up converter, (I'm not gonna be racing my car it's just gonna be a fun street car) now question is when a torque converter says 2400-2800 stall does that mean that 2400 stall will be the lowest it flashes and 2800 will be the highest , but pending on my motors power range it will flash between 2400 and 2800rpms ?......
Old 12-07-2011, 02:59 PM   #2
Don't qoute me on this but I'm pretty sure it depends on how fast your rpms rise.how quick you hit the go pedal may vary when the torque converter locks up.also it does not grab 100% at once.there is a range before it locks all the way up.
Old 12-07-2011, 03:10 PM   #3
BossMach's Avatar
You also need to make sure that your cam comes in around 2200-2500 rpms
BossMach is offline   Reply With Quote
Old 12-07-2011, 03:40 PM   #4
Re: Torque Converter ?
The 2400-2800 RPM rating is a rough estimate of where your convertor will stall to depending upon the torque your engine makes in that range.
A rough estimate of your actual stall speed can be had by holding the foot brake and applying the throttle until the back tires break loose. Note the RPM at which this happens and that gives you a rough idea of the "stall" speed (RPMs) for your car.
Old 12-07-2011, 03:45 PM   #5
Well my motor is a 302 bored to 308 , edelbrock performer heads , edelbrock Performer 5.0 intake with trickflows stage 1 cam , the base power of the cam is 2000rpms
---------- Post added at 04:45 PM ---------- Previous post was at 04:45 PM ----------
I was told by a few guys to go 300-500rpms higher then the base rpms of the cam I'm using!
Old 12-07-2011, 03:50 PM   #6
That sounds like it should work just fine for you.
Happy tire smoke!
Old 12-07-2011, 06:45 PM   #7
Sweet thanks!!!
Torque Converter Dbsaints 2011-2014 Mustang GT 3 09-29-2011 08:55 AM
torque converter question workmail21 1979-1995 Mustang GT 7 08-16-2011 08:15 PM
Torque converter WhiteCobra94 1979-1995 Mustang GT 8 08-05-2011 04:49 PM
Low end Torque V6 ewatts Pre-2005 V6 Mustang 17 07-22-2011 07:21 AM
torque converter access plug? shustwit Pre-2005 V6 Mustang 0 07-03-2011 07:44 AM
01:03 AM
