Do i need an Adj quadrant - Mustang Evolution
Old 12-07-2011, 08:07 AM   #1
Taxman's Avatar
For a ram power grip clutch?
Taxman is offline   Reply With Quote
Old 12-07-2011, 09:28 AM   #2
Its not necessary but will make fine tuning your clutch easier
Old 12-07-2011, 11:35 AM   #3
stampde's Avatar
Re: Do i need an Adj quadrant
You don't need it ,but i would upgrade
2011 GT Auto
Old 12-07-2011, 03:34 PM   #4
If you still have the stock factory plastic quadrant, then I would say yes you do need to replace it.
The factory quad is marginal at best and when you add a beefier aftermarket clutch, failure is pretty much imminent.
There are several benefits to installing an aftermarket adjustable quadrant.
The best are the increased reliability and adjustment.
Old 12-07-2011, 04:30 PM   #5
Filibuster
Yeah when I changed my clutch I kept the stock quadrant..needless to say it didn't last very long!...I believe TH helped me with a few questions as well!...I do remember removing the driver seat because the quadrant is in a very precarious location...
XXSTEVEO66 is offline   Reply With Quote
Old 12-07-2011, 06:20 PM   #6
Taxman's Avatar
I'll order one tomorrow... Thanks for the input
Old 12-07-2011, 06:32 PM   #7
You can get the whole adjustable kit for pretty cheap.it comes with cable quadrant and firewall adjuster.
Old 12-08-2011, 08:50 AM   #8
93redfox's Avatar
Be cautious about the multiple hook quadrants. I had one in the past and the middle hook put a stress point on the cable if i hooked it on the first hook, and I broke several cables over time because of it. I run a Maximum Motorsports quadrant and cable now and I have never had a smoother clutch action. Their cable is where it's at, it is engineered like the oem ford cable. Make sure you get the newer style firewall adjuster that clicks as you adjust it. This style won't slowly back off and need to be readjusted. Some have a jam nut on the threads too to help keep it from going out of adjustment. I tried all kinds of quadrants and cables and finally got my clutch action like it should be with the MM stuff.
93redfox is offline   Reply With Quote
Old 12-08-2011, 04:04 PM   #9
Taxman's Avatar
Thanks man
New quadrant install XXSTEVEO66 1979-1995 Mustang GT 16 08-21-2011 11:36 AM
09:33 AM
