I got a question??? - Mustang Evolution
Old 12-08-2011, 04:36 PM   #1
I got a question???
This is a real dum question but im looking under my hood and standing there scratching my head?? Where is my tranny fluid dip stick???? So I cant check it/add some if nessesry.. Em I dum and cant find it or does it not exist? Lol
---------- Post added at 10:36 PM ---------- Previous post was at 10:36 PM ----------
Can***
94GTx306 is offline   Reply With Quote
Old 12-08-2011, 04:50 PM   #2
if you have manual then you dont have one.there is a fill level plug on the passenger side of the trans.
Old 12-08-2011, 04:54 PM   #3
I can get to it from looking under the hood??
Old 12-08-2011, 05:02 PM   #4
no.younhave to jack the vehicle up.support it on jackstands.climb under the car and on the side of the transmission which would be about directly under you console there will be a pipe plug on then side of it.see pic.but most likely unless you are leaking or having trans trouble you are probably ok.but never hurts to check i guess.
Old 12-08-2011, 05:04 PM   #5
oh yeah,it should be on the passenger side
Old 12-08-2011, 05:24 PM   #6
89 Foxloco's Avatar
Correct.. +1 on all the things that dreamstang said..
89 Foxloco is offline   Reply With Quote
Old 12-08-2011, 11:27 PM   #7
Alright cool thanks
Old 12-09-2011, 10:48 AM   #8
jhagan1980's Avatar
The car should be level
jhagan1980 is offline   Reply With Quote
Old 12-09-2011, 12:37 PM   #9
Re: I got a question???
Make sure you don't remove the wrong "plug", or else you will have to remove the transmission and open it up to put everything back in place.
Happened to a friend of mine and we had to pull the transmission to fix it.
Don't remember exactly, but I think it is a bolt/plug a bit higher located than the actual fill/check plug.
Old 12-09-2011, 05:06 PM   #10
93slowstang's Avatar
A 3/8 socket wrench will be needed to get it out, unless someone put a bolt in its place.
Exhaust question Codysmustang 1996-2004 Mustang GT 14 11-21-2011 10:11 PM
Kenne bell 2.6L question Ahmed ali khan 1996-2004 Mustang GT 4 11-14-2011 01:54 PM
Anotger transmission question. Nick_L Classic Mustangs 1 08-24-2011 05:27 AM
1998 v6 exhaust question?? Gt.Vert Pre-2005 V6 Mustang 6 07-23-2011 01:29 AM
Aft cat deletion question Mustanglife Pre-2005 V6 Mustang 21 06-27-2011 10:30 AM
11:20 PM
