Starting issues - Page 2 - Mustang Evolution
Old 12-10-2011, 10:16 PM   #36
Re: Starting issues
Originally Posted by 351mustang View Post
Even if.. They have to charge it at the store cause if it is bad I have a warranty so they have to verify it with their charger
If their charger is working correctly and your battery will hold a full charge and has been pre-charged by you, their charger should show that right away and negate the need for them to keep it overnight.
It just sounds like a ploy to discourage people from bringing in those types of batteries for testing to me?
Old 12-10-2011, 10:36 PM   #37
351mustang's Avatar
It's possible. I think it's only if you want to have the battery replaced under warranty do they have to charge it in theirs
351mustang is offline   Reply With Quote
Old 12-10-2011, 11:14 PM   #38
Re: Starting issues
Ok, Let us know what you find and good luck that it will be something inexpensive and simple.
Old 12-12-2011, 04:50 AM   #39
mike8748's Avatar
Re: Starting issues
Great Troubleshooting tips guys. I started having the same issues on my 91' yesterday right before I went to work. This will help me out today. Also thanks for posting those pics.
Mike
Orange Park, FL.
mike8748 is offline   Reply With Quote
Old 12-13-2011, 08:27 PM   #40
351mustang's Avatar
Well its the starter. I got it out and the header is in the way. So I can't get it out all the way
Old 12-13-2011, 08:31 PM   #41
Filibuster
Long tube headers?...
XXSTEVEO66 is offline   Reply With Quote
Old 12-13-2011, 08:49 PM   #42
351mustang's Avatar
Yes
Old 12-13-2011, 08:56 PM   #43
Filibuster
Then I would definitely look at gettin a mini starter as TH stated...the heat from the headers could've been part of the death of your starter..and will help insalling and removing it as well!..
Old 12-13-2011, 08:58 PM   #44
351mustang's Avatar
Well that's what I plan on doing. So I probably will have to remove the header to get it out?
Old 12-13-2011, 09:04 PM   #45
Filibuster
Unfortunately yes long tube headers have there pros and cons...clearance issues, removal and insatllation are a few of the cons..
Old 12-13-2011, 11:53 PM   #46
351mustang's Avatar
Do I have to unbolt completely or can I unbolt partly and try and pull it over a bit?
Old 12-14-2011, 07:49 AM   #47
Filibuster
You may be able to unbolt the exhaust at the collector, then just loosen the headers at the head then try to sneak the starter out...I guess it depends on how much more clearance you need!..or if anything just leave one bolt in towards the font of the engine so you can try swinging the header a little bit...
Old 12-14-2011, 08:24 AM   #48
351mustang's Avatar
Not much. Will I need to replace the gasket for the header?
Old 12-14-2011, 10:50 AM   #49
Filibuster
If the gasket is in good shape it can be reused..being that you have aftermarket headers im sure the gaskets are probably felpro, kooks or something similar..but on the other hand if you plan on replacing them now is the time!..they only run about 15-30$ depending on what brand...
Old 12-14-2011, 11:40 AM   #50
351mustang's Avatar
The headers are actually a custom build. The motor was just done so gaskets are all brand new. I think I may just unbolt from the collector and see if I can just push the header out some just to get clearance. Dies anyone know if I need anything different( solenoid) in order to go to a mini starter?
Old 12-14-2011, 12:26 PM   #51
Filibuster
I wouldn't think you'd need a different one...dont quote me on that,but as long as it works I think it'll be fine..
Old 12-14-2011, 02:19 PM   #52
I would not try bending the headers you might crack a weld
tbonestang is offline   Reply With Quote
Old 12-14-2011, 03:25 PM   #53
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
If you get a mini starter from advanced and they want a core they might not accept your old starter. Had that happen to me with an old dodge truck I had long tubes on, ordered a mini starter (basically a dodge Dakota starter) and when I went to get it and give them my old starter they refused to take it and ended up having to pay the core on top of the price of the starter :/
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 12-17-2011, 01:07 AM   #54
deadsp0t's Avatar
When I replaced the starter in my 87 5.0L with a smaller starter from a 95 GT @ advance auto where I live they took the old one as core np. Maybe it will depend on who's working and how much they know. Maybe the issue you had was crossing models? I believe they list the newer starters as a replacement option for older fox cars. Not positive as its been 3-4 years since I went through starter issues on my 87.
That's unimpressive
Old 12-17-2011, 11:37 PM   #55
351mustang's Avatar
Can anyone confirm this? I looked at the starter for a 94 and 95 looks like it mounts the same
Old 12-17-2011, 11:39 PM   #56
Filibuster
Still a fox body platform so I would think they do!..
Old 12-17-2011, 11:59 PM   #57
351mustang's Avatar
And it's smaller?
Old 12-18-2011, 12:12 AM   #58
93slowstang's Avatar
And it's smaller?
Than the 87 starter... Yes
Old 12-18-2011, 12:20 AM   #59
Re: Starting issues
Since you have a 351W (5.8) this might be a better choice for you.
Brand new, no core, $65 and it is from a site sponsor/vendor so you might get a discount. However as it is much cheaper than the 5.0 starter at $119 I wouldn't count on it.
93-95 Lightning 5.8 Starter
Old 12-18-2011, 03:00 AM   #60
351mustang's Avatar
Man I already bought the 5.0 it was 50 bucks so not to bad ill check out the link
---------- Post added at 04:00 AM ---------- Previous post was at 03:58 AM ----------
Only other issue the solenoid is mounted in the starter can I still use my original and not use the one on the starter?
Old 12-18-2011, 03:10 AM   #61
Re: Starting issues
Yes, you can put a bypass strap/wire to use only the fender mounted solenoid.
Old 12-18-2011, 03:15 AM   #62
351mustang's Avatar
Any instructions?
Old 12-18-2011, 03:17 AM   #63
Re: Starting issues
Like this. (This is a Chevy starter, but it should be similar.)
Name:	Starter Mounted Solenoid Jumper.jpg
Old 12-18-2011, 03:19 AM   #64
351mustang's Avatar
Ok so it's just a piece of metal that goes across? Can I pick it up from autozone or something?
Old 12-18-2011, 03:53 AM   #65
Re: Starting issues
Unless you have a starter rebuild shop in town, you will probably have to fabricate one.
Try to make it out of copper or brass so it does not corrode.
I usually just split a piece of soft copper tubing and flatten it out to fabricate electrical bus bars like that.
Old 12-18-2011, 06:30 AM   #66
351mustang's Avatar
Alright and then I would just hook the starter cable up to the bigger post
Old 12-18-2011, 10:26 AM   #67
Re: Starting issues
The cable from your fender mounted solenoid connects to the large top post.
Old 12-18-2011, 10:54 AM   #68
351mustang's Avatar
Sorry for all the questions but what holds the fabed strap down?
Old 12-18-2011, 12:02 PM   #69
Re: Starting issues
There should be a nut on the stud to hold it down.
If not get a brass or bronze nut.
Old 12-21-2011, 01:44 PM   #70
NeedSomeMods's Avatar
Re: Starting issues
While we're on the issue, I'm going to need a starter soon as well. like, now haha.
Will a '94 3.8 v6 starter work on a '94 5.0?
I went to Oreilly's online store, looked up the different car's starters and the part numbers are the same.
---------- Post added at 02:44 PM ---------- Previous post was at 02:35 PM ----------
just checked autozone too.
Part numbers are the same, and the alternators are also the same.
Sounds like it's time dig up that old V6 and swap some parts
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
starting issues bostang99 1996-2004 Mustang GT 15 12-07-2011 10:46 AM
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Starting issues GunMetalBullet 2005-2010 Mustang GT 6 08-06-2011 10:24 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
12:00 PM
