Starting issues - Page 3 - Mustang Evolution
Old 12-23-2011, 08:38 PM   #71
351mustang's Avatar
So I've decided to wire the solenoid on the starter anyone care to share the proper way of doing it? Can I just use a starter wire for the second connection
351mustang is offline   Reply With Quote
Old 12-23-2011, 08:50 PM   #72
Re: Starting issues
Battery cable to the big post, wire from ignition switch to the small post.
But for tuning and working on the engine it's much easier to keep the fender mounted solenoid working.
Old 12-23-2011, 09:35 PM   #73
351mustang's Avatar
Well a guy at this starter rebuild shop said I should take the wire that goes to the battery move it over to the the post with the wire that connects to the starter and take another wire to the post that I moved the one wire over then run the new wire to the solenoid on the starter
Old 12-23-2011, 09:48 PM   #74
Re: Starting issues
Well, take your choice, but if you hook the battery cable to the post that has the wire going into the starter, then your starter will start running and not shut off until you remove the cable.
Old 12-23-2011, 10:00 PM   #75
351mustang's Avatar
So I should not use the solenoid on the starter? Just use the bypass method?
Old 12-23-2011, 10:29 PM   #76
Re: Starting issues
I have not had one of those starters apart so I cannot be sure, but I think you may have to wire it up so it activates the starter drive (pushes the starter gear forward to contact the flywheel starter ring).
By wiring it as I described before with the small bus bar, when you turn on the switch and activate the top fenderwell mounted solenoid it sends voltage/current through that solenoid to the starter mounted solenoid. When the voltage/current hits the starter mounted solenoid top post it also goes through the small bus bar to activate that solenoid to turn the starter and engage the starter drive.
Old 12-24-2011, 08:06 AM   #77
351mustang's Avatar
Is there a diagram I can look at?
Old 12-24-2011, 09:16 AM   #78
Re: Starting issues
I found this on the internet, so disregard what I was telling you before. I was not aware that those starters would backfeed. This is how you should wire it.
Name:	Mustang EFI Starter Solenoid Wiring.png
Old 12-24-2011, 10:58 AM   #79
351mustang's Avatar
So the battery and starter cable are in the same post?
Old 12-24-2011, 12:59 PM   #80
Filibuster
IMO...you are having issues with your starter...so why would you add another possible symptom to this?...
Now you have two solenoids!..if one goes bad you can no longer use the method of jumping it to start it!!..
Sorry for posting so late about this, but was this starter the only one you could find?...personally I would return it and eliminate that extra solenoid!....if it wasn't there I think you would've already saved yourself from this headache!!..
PS this is only my opinion im just trying to help!...
XXSTEVEO66 is offline   Reply With Quote
Old 12-24-2011, 03:09 PM   #81
351mustang's Avatar
Well I'm looking to exchange it for a mini starter due to clearance issues with the headers and heat soak. I'm not sure If they make high torque mini starter with out the starter mounted solenoid
Old 12-24-2011, 03:21 PM   #82
Filibuster
Well I'm looking to exchange it for a mini starter due to clearance issues with the headers and heat soak. I'm not sure I they and high torque mini starter with out the starter mounted solenoid
+ 1 I think you'd be happier goin that route!..
Old 12-24-2011, 03:28 PM   #83
351mustang's Avatar
I edited my last post auto correct on phone lol. But I'm not sure if they make a high torque mini starter with out the solenoid mounted
Old 12-24-2011, 05:14 PM   #84
Re: Starting issues
Yes they are.
They use the fender solenoid to isolate the starter solenoid to prevent any backfeeding of current which will damage the EFI system.
Old 12-24-2011, 05:18 PM   #85
Re: Starting issues
Read the text on the diagram.
They use the fender solenoid to isolate the starter solenoid to prevent backfeeding into the EFI system.
All of the mini starters are made that way because the solenoid also activates the starter drive to engage the starter.
Old 12-24-2011, 08:28 PM   #86
351mustang's Avatar
Ok I will order the starter and the heat shield on Tuesday and give it a shot because there is no way the new clunky starter is going to fit
Old 12-24-2011, 11:02 PM   #87
351mustang's Avatar
http://media.latemodelrestoration.co...ns/pa-1806.pdf
Here is another set instructions. Confused
Old 12-24-2011, 11:48 PM   #88
Re: Starting issues
That's pretty much like the diagram I posted except they are trying to cover several years of cars. Mine is just for our Fox Bodies.
Old 12-25-2011, 12:18 AM   #89
351mustang's Avatar
Alright I'll give it ago. Still confused on which wire moves to what post. I guess worst case it won't turn off and I'll just disconnect. Thanks for the help happy holidays
Old 12-27-2011, 08:25 AM   #90
351mustang's Avatar
Will a starter wire work for the second wire off the fender mounted solenoid
Old 12-27-2011, 08:52 AM   #91
Re: Starting issues
The one that goes to the smaller post on the starter mounted solenoid?
If so, yes it should as long as it is a #12 gauge or larger.
Old 12-27-2011, 03:59 PM   #92
351mustang's Avatar
Also Ive looked around and alot of diagrams are showing the battery cable connected to the left but mine is connected on the right
Old 12-27-2011, 06:11 PM   #93
Re: Starting issues
The left side is where it should be connected.
Some one wired it up wrong.
However, the two big posts lead to the solenoid contacts and it will work either way, but it may have a tendency to burn up the contacts sooner since it is feeding power through the solenoid backwards.
Old 12-27-2011, 06:16 PM   #94
351mustang's Avatar
Is there any difference in newer models I think I have a older model solenoid based on pictures I've seen
Old 12-27-2011, 06:37 PM   #95
Re: Starting issues
Not that Im aware of.
There are many types of solenoids and as long as they will carry the current needed for your vehicle and are for the correct voltage, those that match your needs can be made to fit and work properly.
Old 01-02-2012, 03:54 PM   #96
351mustang's Avatar
Do you know the standard size of the solenoid post 3/8 5/8?
Old 01-02-2012, 05:11 PM   #97
Re: Starting issues
I think it's a 3/8" x 16 thd, but some may be metric nowadays.
Old 01-03-2012, 01:04 PM   #98
351mustang's Avatar
I'm trying to figure out which side of the solenoid I can run the constant power from does it matter
Old 01-03-2012, 02:54 PM   #99
Re: Starting issues
Constant power needs should be connected to the battery connection side.
Name:	Ford Starter Solenoid Connections.jpg
Old 01-03-2012, 06:09 PM   #100
351mustang's Avatar
Thanks
Old 01-03-2012, 06:17 PM   #101
bradh2414's Avatar
If that isn't it, clean your battery connectors and check the battery cables and make sure they're connected everywhere. I had a loose cable and would only get a click sometimes too
bradh2414 is offline   Reply With Quote
starting issues bostang99 1996-2004 Mustang GT 15 12-07-2011 10:46 AM
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Starting issues GunMetalBullet 2005-2010 Mustang GT 6 08-06-2011 10:24 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
08:55 AM
