Starting issues - Mustang Evolution
Old 12-10-2011, 01:52 PM   #1
351mustang's Avatar
Starting issues
I go to start the car and I get nothing no click it just goes dead. The battery is charged and everything works when the key is in the on position any ideas?
351mustang is offline   Reply With Quote
Old 12-10-2011, 01:53 PM   #2
Try jumping the silinoid .if that doesn't work have the starter checked.
Old 12-10-2011, 02:00 PM   #3
351mustang's Avatar
I'm unfamiliar with jumping the solenoid you mean hook a jump box up to it?
Old 12-10-2011, 02:06 PM   #4
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Grab a screwdriver and touch one post on the solenoid on the drivers side fender then while still touching that post, touch the other post, make sure your car is in neutral or park before you do this!!
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 12-10-2011, 02:07 PM   #5
Elfman's Avatar
I had the same problem after i put the new engine in my car. The solenoid went. Also check the negative battery lead that connects to the battery. You will have to tighten u where the wire connects to the terminal thing. Make sure you clean the battery terminals and leads
Elfman is offline   Reply With Quote
Old 12-10-2011, 03:21 PM   #6
Re: Starting issues
If the battery is fully charged and does not have a dead cell, then your starter solenoid or switch must be bad.
When jumping the solenoid, jump from the large cable connected to the battery to the small terminal marked "S" on the solenoid. Make sure the car is in park if auto trans or out of gear with the emergency brake on if manual. Be sure to turn the switch on if you want to start the engine.
Old 12-10-2011, 03:30 PM   #7
351mustang's Avatar
I'll try replacing to solenoid thanks
Old 12-10-2011, 03:43 PM   #8
Did you jump it?iwould definitely try it first before you replace.it is really easy and only takes a minute.
Old 12-10-2011, 03:48 PM   #9
351mustang's Avatar
E brake doesn't work. But I did pop the clutch and it started it up so i was able to get it to my storage unit
Old 12-10-2011, 03:52 PM   #10
You can still jump it.just make sure you are in neutral like Trojan suggested.if you are still worried chaulk the wheels.
Old 12-10-2011, 03:59 PM   #11
351mustang's Avatar
Good point so I just take a screw driver to the s and then what
Old 12-10-2011, 04:04 PM   #12
Filibuster
Then you just make a connection to the other post...there will be a few sparks,but you'll know right away if it starts the selinoid was the problem!..
XXSTEVEO66 is offline   Reply With Quote
Old 12-10-2011, 04:06 PM   #13
351mustang's Avatar
Ok forgive my ignorance I've heard of this but haven't ever tried it so I take a screwdriver to the s and what do I connect it with to the the wire going to the wire from the battery terminal
Old 12-10-2011, 04:17 PM   #14
Filibuster
Hope this helps...as you can see ive replaced mine as well!...I jumped it and drove straight to the auto parts store!..I just left it running until I got back home to replace it..
Old 12-10-2011, 04:20 PM   #15
351mustang's Avatar
Ahhh I feel dumb however I don't think I can achieve that I'll take pics of my solenoid the I have two small post on mine
Old 12-10-2011, 04:41 PM   #16
Just use a screwdriver or piece of wire and touch the 2 post together.
Old 12-10-2011, 04:44 PM   #17
351mustang's Avatar
Ok if it starts up then I have a bad solenoid?
Old 12-10-2011, 04:52 PM   #18
Filibuster
Yup!..
Old 12-10-2011, 04:53 PM   #19
Yup!..
+1
Old 12-10-2011, 04:55 PM   #20
351mustang's Avatar
Thanks
Old 12-10-2011, 05:14 PM   #21
No problem,glad to help.
Old 12-10-2011, 06:14 PM   #22
351mustang's Avatar
Here is the pic
Old 12-10-2011, 06:31 PM   #23
351mustang's Avatar
Hooked up the wire no go didn't start just heard clicking. So is it the starter?
Old 12-10-2011, 06:47 PM   #24
Yes I think it is.I would take it off and have it tested.your local auto zone or advanced auto will test it for ya.
Old 12-10-2011, 07:10 PM   #25
Re: Starting issues
Have your battery load tested too and make sure it doesn't have a dead cell.
Old 12-10-2011, 07:26 PM   #26
351mustang's Avatar
Well I did when I first started( pun intended) having issues it was hood but I guess that's not to say it didn't go bad it was about two weeks ago
---------- Post added at 08:26 PM ---------- Previous post was at 08:24 PM ----------
I should just be able to get a starter for a 302 correct?
Old 12-10-2011, 07:27 PM   #27
doesnt hurt to have it tested even if it was recently tested especially since you have to go to autozone anyways.plus if you have been trying to get it started for a while you may have drained your battery some.so if you dont have a charger but you battery is ok it will still benifit you taking it in cause autozone will even charge it for you.
Old 12-10-2011, 07:29 PM   #28
351mustang's Avatar
Well I do have a charger but the only thing is I have one of those optima batteries and they have to keep it over night
Old 12-10-2011, 07:30 PM   #29
i am pretty sure but someone else may have to verify that for you.
Old 12-10-2011, 07:40 PM   #30
Re: Starting issues
Get the starter for a.......?
Aaarrgh! I forget what year, but get the mini starter so you'll have additional clearance.
I think 92-93 is when they started using the smaller gear drive starters on 5.0 Mustangs, but don't hold me to that.
Why do they have to keep your Optima overnight?
Old 12-10-2011, 07:44 PM   #31
Re: Starting issues
P.S. While I'm pretty sure it will bolt up you might want to take your old starter to compare mounting and depth.
Old 12-10-2011, 08:31 PM   #32
351mustang's Avatar
Yeah I will
---------- Post added at 09:31 PM ---------- Previous post was at 09:30 PM ----------
Because they say they have to trickle charge it because it's a gel battery
Old 12-10-2011, 08:32 PM   #33
good idea!
Old 12-10-2011, 08:44 PM   #34
Re: Starting issues
But you have a charger, so just disconnect it and charge it before you take it there.
Old 12-10-2011, 08:51 PM   #35
351mustang's Avatar
Even if.. They have to charge it at the store cause if it is bad I have a warranty so they have to verify it with their charger
starting issues bostang99 1996-2004 Mustang GT 15 12-07-2011 10:46 AM
Interior Issues? Dion11197 2011-2014 Mustang GT 20 12-05-2011 06:55 AM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
Starting issues GunMetalBullet 2005-2010 Mustang GT 6 08-06-2011 10:24 PM
Starting Issues bradh2414 Pre-2005 V6 Mustang 25 07-14-2011 08:43 PM
12:44 AM
