Oil in my air intake - Mustang Evolution
Old 12-12-2011, 07:42 PM   #1
Contourdrew's Avatar
I took my cold air intake off today to clean it and found oil inside of it and also oil in the throttle body on the flap any ideas as to what it could be
Contourdrew is offline   Reply With Quote
Old 12-12-2011, 08:03 PM   #2
i just recently read about this problem.let me see if i can find it.
---------- Post added at 09:03 PM ---------- Previous post was at 08:43 PM ----------
its got to be something along the lines of pcv valve,the hose that connects it or anything around that area.if you have aftermarket valve covers do they have baffles in them to prevent the oil from getting in the pcv valve?
here is a link from stangnet. http://www.stangnet.com/mustang-foru...e-tube.609340/
Old 12-12-2011, 11:48 PM   #3
workmail21's Avatar
I have this same problem I was told it might be blow by or else is the pcv valve might be clogged haven't looked into it that much yet so im not sure this I right or not.
workmail21 is offline   Reply With Quote
Old 12-13-2011, 02:12 AM   #4
Re: Oil in my air intake
If it is in front of where the PCV hooks up and has a K&N or other cotton, oiled style filter, then someone has over oiled it or not let it dry properly.
Clean everything inside especially the MAF sensor.
If it occurs after the PCV connection and is excessive then you may have worn rings and some blowby.
With the engine idling at normal operating temperature remove the oil fill cap and see if it puffs up out of the valve cover. If it does then blowby is the problem.
Best cold air intake? Pstang5 2011-2014 V6 Mustang 11 12-27-2011 07:47 AM
cold air intake pondit0 1996-2004 Mustang GT 1 11-22-2011 09:16 AM
Oil in upper intake? 5.8GT 1979-1995 Mustang GT 5 11-19-2011 11:28 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
04:34 PM
