2 questions on brakes. - Mustang Evolution
Old 12-13-2011, 06:26 AM   #1
All4sho's Avatar
Hi everyone, this is my first post. Hopefully someone can help me. I have an 88 GT and am doing a 5 lug swap. I have all the goodies for the front (sn95 spindles, rotors, calipers) I have stock length rear 5 lug axles out of 2 rangers. When I bought the car I got a rear disc conversion with it missing some part. My first question is, I plan on getting mid 80s turbo coupe rear rotors and pads. Is that correct? Second question is, it is missing e-brake cables. Would I get 93 cobra w/disc brake cables? Last question, would I need to get a different distribution block for the brake booster to flow enough fluid to have enough power for the rear calipers or will the stock block work? Hope someone has done this or knows someone who has. Thanks.
---------- Post added at 08:26 AM ---------- Previous post was at 08:25 AM ----------
Sorry that was 3 questions.
All4sho is offline   Reply With Quote
Old 12-13-2011, 07:44 AM   #2
Meansaleen's Avatar
You can use the rear brakes from an 80's SVO. Or I believe you can use the Lincoln
Mark VII brakes. Yes u would need a different master cylinder than The one u have I'm sure someone will chime in with better info.
Meansaleen is offline   Reply With Quote
Old 12-13-2011, 08:48 AM   #3
All4sho's Avatar
Ok you are saying the SVO or lincoln rotors and pads? I have the calipers and mounting hardware. Would the master cylinder off the SVO or lincoln work also? If so that would be easy.
Old 12-13-2011, 09:07 AM   #4
Meansaleen's Avatar
Yes the master cylinder will work from those cars. Remember Saleen used the braking system from the 84 SVO mustang for there 87-93 fox bodies
Old 12-13-2011, 09:45 AM   #5
All4sho's Avatar
Ok, that's cool. Thanks.
95 GT questions deadsp0t 1979-1995 Mustang GT 54 11-04-2011 02:16 PM
New Brakes Timm04 Pre-2005 V6 Mustang 6 09-22-2011 01:28 PM
conversion disc brakes? 1faststang Classic Mustangs 15 08-11-2011 01:30 AM
Nitrous Questions Murdered_Stang 2005-2010 Mustang GT 2 07-19-2011 12:00 AM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
09:56 PM
