Porting stock 5.0 heads - Mustang Evolution
Old 12-16-2011, 09:06 AM   #1
SmokedLX's Avatar
Has anyone ported and done a valve job on their stock 5.0 heads? I can get them fully rebuilt and ported for $350... Will i get a good enough hp gain per dollar going that route?
1991 Mustang LX - Rebuilt 302, cobra 80mm MAF, 75mm Trickflow Throttle Body, Ported GT40 Intake manifold, half inch plenum spacer, Ported trickflow twisted wedge heads w/ trackheat valvesprings, Scorpion 1.6 Roller Rockers, stock cam (for now), 24# injectors, trickflow pushrods, shorty headers, H-pipe with 4 magnaflow high performance cats, flowmaster 40s w/ axle dumps, 4.11 gears, aluminum driveshaft, Built AOD w/ 2800 stall, 16" Cobra R replicas, 245/50ZR16 street slicks...hopefully procharger next
SmokedLX is offline   Reply With Quote
Old 12-16-2011, 05:09 PM   #2
SleepingStang's Avatar
I would think for that money I would get a set of GT40 heads and just have them rebuilt if they are questionable. I think the stock heads with a rebuild and port would not show a big gain especially if you are planning further mods. Just my opinion.
SleepingStang is offline   Reply With Quote
Old 12-16-2011, 05:12 PM   #3
There is a site in the stickies diy porting.it has some real good porting and flow info on those heads.
Old 12-16-2011, 10:43 PM   #4
Re: Porting stock 5.0 heads
+1 DIY or save the money for a better set.
Old 12-17-2011, 08:36 AM   #5
SmokedLX's Avatar
But i can get a full port and rebuild for that price, not just a port job
Old 12-17-2011, 08:53 AM   #6
A rebuild is usually just replacing the valve seals and regrinding the valves and seats. Not really worth it IMO.
Old 12-17-2011, 10:30 AM   #7
SmokedLX's Avatar
So what options are out there for aroud $300-$400?
Old 12-17-2011, 11:32 AM   #8
I forget the exact ones but go to the junk yard and pull the heads and intake off an explorer(96-98 maybe)they are gt40.the same heads used on 95 cobras.then pay to get those ported and u will see a decent gain.
Old 12-17-2011, 11:34 AM   #9
For a little more, + assembly parts - Pro Comp Aluminum Heads
Old 12-23-2011, 04:54 AM   #10
2300turboford's Avatar
Get a 5 angle valve job it helps a lot and if u can bigger valves and port it
Old 12-27-2011, 10:46 AM   #11
SmokedLX's Avatar
5 angle valve job on the factory heads?
Old 12-27-2011, 12:10 PM   #12
Whether or not a 5 angle valve job or even a 3 angle valve job will make much, if any difference is going to depend upon how the intake/head flows or has been ported to flow.
Sometimes it may help, other times it may do nothing at all or even have negative effects.
More of that, "Make sure your parts and mods match or compliment each other" wisdom gained from experience.
Old 01-01-2012, 12:57 AM   #13
Thank you i didn't know that
Stock Heads, Cam and Intake! WhiteCobra94 1979-1995 Mustang GT 12 12-23-2011 02:05 PM
Installing a supercharged 3.8 from a thunderbird SC into my 99 mustang skip318 Pre-2005 V6 Mustang 12 10-01-2011 09:03 PM
Fastest stock 5.0 wnt2gofst 2011-2014 Mustang GT 2 09-01-2011 05:23 PM
Cumbustion chamber size Mustang1968kr 1979-1995 Mustang GT 2 08-23-2011 11:51 AM
04:25 AM
