e brake - Mustang Evolution
Old 12-16-2011, 02:08 PM   #1
mystang50's Avatar
e brake
Is my ebrake supposed to lock up tires when driving down road? Cuz mine don't...it'll hold it still when in N at a stop but won't lock em up, and another thing is when I floor it my parking brake light will come on and stay on till I let of and press gas agian.and when I go to stop at a light or something the light will come on till I give it some gas...there is plenty of fluid and everything Jus curious to get yalls opinions
Old 12-16-2011, 10:41 PM   #2
Re: e brake
You need to adjust your E-brake or your back brakes are getting to be worn out.
Old 12-17-2011, 09:25 AM   #3
mystang50's Avatar
Re: e brake
how do u adjust the ebrake??
Old 12-17-2011, 09:39 AM   #4
Re: e brake
Not sure on the 94-95 models.
I let my Chilton's manual go with the car when I sold it.
Pick on up at your local auto supply.
They are not that expensive and they have lots of useful info and diagrams.
Old 12-21-2011, 05:43 PM   #5
88fox's Avatar
That just started happening with me also
88fox is offline   Reply With Quote
Old 12-22-2011, 11:46 AM   #6
89 Foxloco's Avatar
Am not sure if this will help the main mustang for the brake question but for the foxs look behind yore back brake..on the bottom their will be a lil hole and a small gear inside..get a flat headed screw driver and adjust it with that..
89 Foxloco is offline   Reply With Quote
Old 12-22-2011, 03:48 PM   #7
Re: e brake
That's the rear brake adjustment used to get your rear brakes initially set up when installing new shoes. After that, if you have installed them correctly they are self adjusting and you shouldn't have to mess with that adjustment.
The E-Brake adjustment takes all the slack out of the cables, so that it works properly.
Old 02-08-2012, 09:54 AM   #8
captain78's Avatar
Where's the e brake adjuster
captain78 is offline   Reply With Quote
Old 02-08-2012, 10:11 AM   #9
Re: e brake
You would have to check a manual to be sure, but I think there is an adjustment nut at/on the E-brake mechanism and maybe an adjustment coupling in the cables under the car too.
Old 02-08-2012, 10:19 AM   #10
captain78's Avatar
I'll check cause e brake dosnt start to grab until all the way up. And then once there. It barley grabs and dosnt hold anything. Brakes are all new and strong and adjusted right
Old 02-08-2012, 10:49 AM   #11
Re: e brake
The cables stretch out over time.
When replacing brakes everything related should be adjusted.
You may need to replace the cables if they have stretched too far to be adjusted any more.
Old 02-08-2012, 10:59 AM   #12
captain78's Avatar
Imma check it out when I get home I'm offshore right now. But gonna get a plate and insurance a drive it for first time. Can't wait bought the car in dec and still haven't drove it lol been working on getting it road ready. And it's almost there. All new everything to do with brakes minus the e brake lol. New rack and pinion. All new vacuum lines light bulbs seats new hurst shifter. Light switches. AC compressor radio and speakers new wheels and tires now I can get started on suspension. Upper and lowers. Subframe connectors from MM. Remove rear quad shock due to tires rubbing. Torque box braces upper and lower. Then on to engine mods
---------- Post added at 11:59 AM ---------- Previous post was at 11:58 AM ----------
And 3:73s
Weird brake thing that happened RVAStang05 2005-2010 Mustang GT 0 11-12-2011 06:51 AM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 07:47 PM
Brake upgrade!!! gvstack 1979-1995 Mustang GT 1 10-27-2011 02:16 PM
Has anyone solved the low brake fluid issue? Pabsny 2005-2010 Mustang GT 5 10-12-2011 09:10 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
12:02 AM
