Alt problem? - Mustang Evolution
Old 12-17-2011, 08:47 PM   #1
Cm644rodrigues's Avatar
Alt problem?
As driving my 87 today in third and Roma dropped off to zero amp light and batt light came on so I pulled off and checked batt connections and alt connections. Everything was fine. Car started right up and I continued on til I got home. This came out of the blue. What's going on is my alt dying?
Cm644rodrigues is offline   Reply With Quote
Old 12-17-2011, 09:05 PM   #2
Your local AutoZone will test it for you.
Old 12-18-2011, 12:59 AM   #3
Re: Alt problem?
Sounds like the alternator quit charging.
If you have a voltage tester and the car will still start, hook up the tester to the battery and start the engine. Make sure it is in park or neutral as required and the e-brake is set.
Right after startup your voltage should be around 14 -14.5 volts and after it has run a bit it may drop off to 12.5 - 13.5. That shows you the alternator is charging. If it doesn't, then the alt is not working or the voltage regulator has failed.
Old 12-18-2011, 09:49 AM   #4
jwhayne0001's Avatar
I've had decent random luck tapping the alt with a hammer while watching the volts and SOMETIMES will temporarily knock the brushes down but it isn't permanent
jwhayne0001 is offline   Reply With Quote
Old 12-18-2011, 07:34 PM   #5
86TBarHatch's Avatar
Region: New Hampshire
I replaced the regulator in mine the other day and it fixed all my charging/voltage drop issues.
86TBarHatch is offline   Reply With Quote
Old 12-19-2011, 01:05 PM   #6
Regulator? Can you explain a little
Old 12-19-2011, 04:18 PM   #7
Re: Alt problem?
The regulator, regulates the voltage coming out of the alternator.
If you have a 2G alternator it looks like this - 2G Alt
Old 12-19-2011, 08:51 PM   #8
aegischief's Avatar
+1
Most likely
A failing alternator. Have it tested.
aegischief is offline   Reply With Quote
Clutch problem 96 stang 1979-1995 Mustang GT 4 09-14-2011 10:38 PM
Fuel problem help! NateNasty 1979-1995 Mustang GT 51 09-13-2011 03:37 PM
Need Help Engine Problem! PonyBoyV6 Pre-2005 V6 Mustang 6 08-30-2011 05:16 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 09:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 12:52 PM
09:48 AM
