1990 gt vert.... - Mustang Evolution
Old 12-19-2011, 06:09 PM   #1
Drewyork's Avatar
1990 gt vert....
Has anybody used or can recommend a 4bank eliminator chip???they promise 20+ rwhp is this true...my car is far from stock and I just wanted to see if what they say is true..and if it's worth adding...
Drewyork is offline   Reply With Quote
Old 12-19-2011, 06:40 PM   #2
A lot of guys around here use it and recommend it.I think u would be happy.here's a old thread about it. sct 4 bank eliminator chip
Old 12-19-2011, 06:47 PM   #3
Drewyork's Avatar
I'm pushing about 315 rwhp now..I wanted to get it up to about 330 340....can a chip get me there??
Old 12-19-2011, 06:53 PM   #4
What u running,full bolt ons?and currently don't have any tune/chip?
Old 12-19-2011, 07:06 PM   #5
Drewyork's Avatar
I have gt 40 intake upper and lower,70mm throttle body.bbk Cold air intake. Ford racing 3.73 gears,bbk under drive pullys,2.50 cat back straight pipes with flow-masters.....plus steeda springs,kyb shocks. Sub-frame connecters...I was thinking a chip before I get into heads,cams.etc
Old 12-19-2011, 07:08 PM   #6
deadsp0t's Avatar
That's unimpressive
Old 12-19-2011, 07:13 PM   #7
U prolly not making 315whp without heads and cam.but either way u should still get good gains.I think the only con would be that u may have to send it in when u decide to upgrade your tunes as u mod.so u will be without for a couple weeks .
Old 12-19-2011, 07:19 PM   #8
Drewyork's Avatar
I've been seeing a lot of good remarks off the thread. I think I'm gonna order one right now...when I get to the heads,cams,etc. that's when I'll worry about finding a tuner....thanks for the info. Much appreciated.
Old 12-19-2011, 07:25 PM   #9
They don't really make a tuner(handheld)for our vehicles.but like I said u can get your upgraded when you add/subtract mods.
They do make a more advanced tuner option that I can't vouch for but looks good.
---------- Post added at 08:25 PM ---------- Previous post was at 08:24 PM ----------
http://www.andersonfordmotorsport.co...chk=1&Itemid=1
Old 12-19-2011, 08:17 PM   #10
Brett Greene's Avatar
315 rwhp? No where near that with those mods bro. Sorry to burst your bubble. More like 250 maybe
Brett the best Greene
Brett Greene is offline   Reply With Quote
Old 12-19-2011, 08:21 PM   #11
Filibuster
+ 1
XXSTEVEO66 is offline   Reply With Quote
Old 12-19-2011, 08:55 PM   #12
WhiteCobra94's Avatar
My old neighbor bought a 91 lx 5.0/302 and thought the 302 was the horsepower and not the cubic inch, so after gears, full exhaust , throttle body and pulleys he tried telling everyone it was a 400hp fox body haha!!
Old 12-20-2011, 07:49 AM   #13
Drewyork's Avatar
First off your not bursting anyone's bubble....believe me I know my ****...your buggin if you think I'm pushing 250. 315 might be pushin it a little bit but I'm above 250 for sure....I forgot to write I have long tube headers on it too....a full exhaust upgrade gives you 25hp+ right there...
Old 12-20-2011, 07:50 AM   #14
Ok dude lol
Old 12-20-2011, 08:30 AM   #15
93slowstang's Avatar
Sorry but if that's the case I have at least 360 easy. With your upgrades your looking at around 270 to the flywheel.
Old 12-20-2011, 10:09 AM   #16
+ 1
Old 12-20-2011, 10:21 AM   #17
It's a common misconception to take the advertised gains from all your parts to guess hp.it never works because those are most likely the best gains you will get w/ perfect tune and environment and supporting mods.I am going with the 250-270 guess.
Old 12-20-2011, 03:02 PM   #18
Sorry unless he has the dyno to show Im guessing 200 rwhp
tbonestang is offline   Reply With Quote
Old 12-20-2011, 03:05 PM   #19
Probably,I was basing of stock 225 crank power
Old 12-20-2011, 03:07 PM   #20
Re: 1990 gt vert....
PMS by EFI Systems
+1
The AFM PMS is one of, if not the best piggyback/handheld tuner options for the 86-95 Mustangs. I have one, but have been unable to work on my car and install it yet due to injuries and a long recovery period.
I did a boat load of research before buying one as they are quite expensive, but the abundant tuning options and not having to send in a chip each time I decided to make some changes are what sold me on it.
Here is a list of what they will tune:
EFI-Systems Series 4 PMS 89-93 5.0 Mustang
The most powerful and the winningest Piggy back Computer in NMRA History
And Here’s why.
. Plug n play. No wiring needed
. View screen on key pad monitoring spark timing, rpm, injector function, throttle position, load range, water temp, air charge temp, manifold pressure, mass air voltage.
. Full tuning ability through Key pad (no lap top needed)
. Full sequential stand alone.
. Real time tuning. While engine is running.
. No waiting for flashing or uploading.
. Tuning from idle to 9900 rpm in fuel and timing in 500 rpm increments
. Tuning by boost. Up to 30lb with 3 bar map sensor
. Tuning for Nitrous.
. Tuning by air charge temp or water temp for fuel and timing
. Individual cylinder tuning for both fuel and timing
. Start fuel setting which controls the injectors when the starter is turning the engine over. This gets ride of the hard starting with 42lb injectors or bigger
. Two step rev-limiter
. Two programmable output switches by RPM/TPS
. Stores three separate tuning programs
. 100% more powerful with twin processors than FORD ECC computer
Old 12-20-2011, 03:12 PM   #21
Originally Posted by Trojan Horse
+1
And Here’s why.
I have no need for it so cannot honestly vouch for it.but I've seen u recommend it so many times and with researching there is nothing that compares to it.almost can consider it unlimited tunability.
Old 12-20-2011, 03:16 PM   #22
Filibuster
+1
And Here’s why.
Sounds like fun....even has the two step on there!..
Old 12-22-2011, 01:18 AM   #23
Here is a YouTube clip of a 1995 Mustang GT on a dyno with BBK headers, BBK off road x-pipe, Mac Cat-backs, BBK intake spacer, BBK underprice pulley kit, BBK Cold air intake with 3.73 gears , the mustang does 2 dyno pulls, the first was 187.46rwhp / 238.43 ft/torque and the 2nd pull was 190.56rwph / 243.46 ft/torque . That's no where close to 315 rwhp from the mods listed in the beginning of this thread!!
Watch the clip here
New 1990 gt captain78 1979-1995 Mustang GT 99 12-23-2011 08:25 PM
1990 mustang gt Drewyork 1979-1995 Mustang GT 17 12-01-2011 06:53 PM
What gears for my automatic 2012 GT Vert mikona 2011-2014 Mustang GT 16 11-07-2011 01:46 AM
03-04 Vert GT Brett Greene 1996-2004 Mustang GT 3 10-14-2011 08:25 AM
1990 mustang GT mustangcobra90 1979-1995 Mustang GT 12 06-25-2011 10:29 PM
03:04 AM
