Help engine keeps cranking - Mustang Evolution
Old 12-19-2011, 10:11 PM   #1
VENOM's Avatar
Hello Guys can you please help ?
I've gone through 3 Solenoids in less than 8 months they keep getting stuck. The first time it happen it drain my battery completely, since then I got a optima yellow top battery new 4gauge cables + and - but the same thing keeps happening, could it be that the SOLENOID that Im buying is a cheap made in CHINA PEP BOYS brand or could it be something else?
YOUR HELP WILL BE GREATLY APPRECIATED. THANK YOU PAUL
VENOM is offline   Reply With Quote
Old 12-20-2011, 01:08 AM   #2
89 Foxloco's Avatar
You probably have a short around your car that is making bad connection causing the silenoid burn and that one messes up the whole battery.. Check the cables that go to the starter.. Or any loose bolts from the ground cable.those are my only suggestions..
89 Foxloco is offline   Reply With Quote
Old 12-20-2011, 08:01 AM   #3
VENOM's Avatar
Thank you Foxloco for your help I'll do that . One thing that I forgot to mention is that the solenoid issues that I'm having is on my 91 mustang not on my 95 because the starters are different , thank you again.
Old 12-20-2011, 11:32 AM   #4
WhiteCobra94's Avatar
I'm having the same prob and I cant figure out where the short is coming from so now when I'm not driving my car I take my battery out and put it on a trickle charger till the next time I use it.
Old 12-20-2011, 01:16 PM   #5
Re: Help engine keeps cranking
It sounds like your starter may be dragging and over amping the solenoids, but it could be a cheap solenoid issue too.
Replace the solenoid with a good quality one and see if that fixes it.
If not then you should probably remove the starter and have it tested.
Or, have the starter tested first then replace the solenoid, however you wish to do it.
Old 12-20-2011, 01:20 PM   #6
deadsp0t's Avatar
+++ I would add to check the main grounds. Bad grounds can cause all
Kinds of havoc!
That's unimpressive
Old 12-20-2011, 01:27 PM   #7
VENOM's Avatar
My 91 has the solenoid by the battery and my 95 has the solenoid on the starter . My 91 is the one I'm having issues with. What year is yours? I thought maybe the ignition in the counsel but wires look ok.
---------- Post added at 12:27 PM ---------- Previous post was at 12:22 PM ----------
Thanks guys for your help!!!
Unsure of my engine Nate98stang 1996-2004 Mustang GT 11 12-13-2011 08:17 AM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
07:17 AM
