Intake options? - Mustang Evolution
Old 12-20-2011, 06:27 AM   #1
All4sho's Avatar
Intake options?
I have an 88 gt. Vortech s-trim pushing 8psi, 70mm throttle body, gt-40p heads, 1.70 roller rockers with shorter push rods, bbk shorty headers, mass air conversion, stock cam. I have a couple choices for intakes. Was looking for some help on what I should pick up. (1) GT-40P upper and lower, (2) Comp Polymer or a Trick Flow (street heat) upper and lower. I am looking for the best one for what I have done to this point. Any goods and or bads that anyone has come across with any of them would be greatly appreciated. Thanks.
All4sho is offline   Reply With Quote
Old 12-20-2011, 08:35 AM   #2
93slowstang's Avatar
Out of those 3 I would go with the trick flow. It looks great and has a great flow rate as well.
Old 12-20-2011, 10:41 AM   #3
WhiteCobra94's Avatar
You also can check out Edelbrock performer RPM II intake
Old 12-20-2011, 10:55 AM   #4
Gster's Avatar
I had the GT40 intake on my 95 GT and loved it. I didn't have a supercharger, but I had the MAF and throttle body with magna flow exhaust from headers to hi pipe to muffler.
---------- Post added at 01:55 PM ---------- Previous post was at 01:55 PM ----------
Sorry. H-pipe. No cats
Gster is offline   Reply With Quote
Old 12-20-2011, 11:22 AM   #5
All4sho's Avatar
I have the gt-40p intake. A friend has the trick flow and another friend has the comp intake. I am trying to figure out if it would b worth picking up one of the other intakes instead of using the gt. would be worth it to me to port and polish the gt intake and say the hell with the other 2? I hope to figure it out soon first weekend of the new year I am tearing the car apart.
Old 12-20-2011, 11:50 AM   #6
You should be fine with the gt40 intake. Porting it wouldn't hurt a bit, and may flow more than the track heat intake after a port job.
Old 12-20-2011, 11:57 AM   #7
All4sho's Avatar
That's good to know. Thanks.
Old 12-22-2011, 04:26 PM   #8
88fox's Avatar
I agree in my opinion I would run with the RPM II
88fox is offline   Reply With Quote
Old 12-22-2011, 07:09 PM   #9
04machazblue's Avatar
Don't forget holly system max they did a study on mmff and the holly, trick flow, and edelbrock all showed to be pretty equal my friends runs a holly system max system and he puts 590hp to the wheels o and it's turbo'd
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-22-2011, 07:42 PM   #10
All4sho's Avatar
I was asking about the 3 I have listed for the fact that that I either have them or can get them for a great price. I have the gt-40p intake. But 2 friends have the other two intakes for cheap. From the feedback I am getting I might just stay with the gt intake port, polish and gasket match it and give it a shot. I know there are alot of intakes out there that are as good or better but I would have to drop some big $$$, more than I would if I picked up one of the other ones.
Old 12-22-2011, 09:31 PM   #11
Taxman's Avatar
Will your buddy's ship? I'm looking for an intake now....
Taxman is offline   Reply With Quote
Old 12-23-2011, 02:55 AM   #12
Re: Intake options?
I have the Comp Polymer upper to fit my Cobra lower, but I'm concerned about a plastic intake being able to stay sealed up under boosted conditions.
Why don't you try that one and let me know how it works out?
Out of the three, I'd get the Trick Flow.
If you have the money for another choice, I'd go with the Systemax recommendation.
From what I have read it works really well with boosted engines.
Old 12-23-2011, 10:42 AM   #13
All4sho's Avatar
I don't think they will ship them, sorry. The comp intake does hold up to boost. The guy who has the comp bought it for his supercharged 5.0 but wrecked it before he got it on. His friend has one on a car with 10psi from a vortech and has yet to split it. Like I said I don't know what to get. They all have their pros and cons just trying to get the one with more pros. I do appreciate the input, thank you.
Old 12-23-2011, 02:37 PM   #14
Re: Intake options?
That's good to know that they will hold up to boost.
But if it ever backfires very hard I bet it would be toast.
Old 12-23-2011, 02:55 PM   #15
All4sho's Avatar
That is true. I guess we will find out how tough they really are. They say they work really good on boosted motors but at high rpm. Don't get me wrong, I will run it up now and then. I am looking for an intake that works well throughout the entire rpm range. Out of the 3 I have to chose from.
Old 12-23-2011, 08:53 PM   #16
Re: Intake options?
The "very" short runners on the box intakes work well on boosted engines too. If you have pressure to the intake you don't really need all that much intake runner length for low end torque.
Old 12-23-2011, 09:07 PM   #17
All4sho's Avatar
That's what I have been told. But I want power throughout the band. I am leaning towards the comp because I know it will run like a raped ape when I lean into it. You know how it is when you are just driving along and the "kid" pulls up next to you and thinks his ricer is the cats ***.
Old 12-23-2011, 09:21 PM   #18
Re: Intake options?
What does the Comp upper fit?
Make sure it fits your lower, or do you get the Comp and lower together?
Old 12-23-2011, 09:38 PM   #19
All4sho's Avatar
The comp bolts to the the factory lower. If I get it I am going massage it a little bit. Gasket match it and a little more to let it flow smoother.
Old 12-23-2011, 09:50 PM   #20
Re: Intake options?
Gasket matching and a little polishing and smoothing of the intake runners will definitely help.
Old 12-23-2011, 09:59 PM   #21
All4sho's Avatar
Yeah, it is still up in the air right now. Next week the motor goes under the knife, so I have to make my mind up very soon. I just want the most punch for the money I am going to spend. Next year will be different story. I have a bear block that is getting built to hold 10-12psi. Look the hell out!
Old 12-23-2011, 10:16 PM   #22
Re: Intake options?
Are you using a stock block?
If you are I would offer some advice if you wish?
Old 12-23-2011, 10:27 PM   #23
All4sho's Avatar
Yeah stock block. Going to drop the compression to around 7:1 all new internals. Starting fresh and going from there. My goal is to have it done by next winter so when the snow is flying I am wrenching in a nice warm garage. Merry Christmas to me!
Old 12-23-2011, 10:44 PM   #24
Las0mbra's Avatar
That's reaaaally low... 8:1 should be low enough.
Old 12-24-2011, 12:12 AM   #25
Re: Intake options?
7:1 compression is quite low.
For internals make sure you choose good quality forged crank, rods and pistons. They are going to be subjected to some pretty extreme stresses.
For the boost pressures you are looking at and the HP you are likely to develop, I would definitely consider installing the DSS Main Support System and the Valley Girdle Pro to help strengthen the block and maybe prevent it from splitting down the middle as they are prone to do.
To seal up your heads to the block and hold in the extra cylinder pressure may require a specific grade finish to the block deck. Check with your head gasket of choice's manufacturer to see what is required. I know the Cometic MLS gaskets require a 50 RA or finer finish.
CamQuest can help you choose the proper camshaft for your build.
Better lubrication flow can be obtained by thoroughly cleaning, polishing (with a die grinder or Dremel) and rounding off any sharp edges of the oiling passages. If possible, slightly enlarging the passage from the oil filter to the oiling system passages helps the flow considerably.
(I did all of this on a 429 Ford engine. The results were excellent. When starting the engine, it had oil pressure immediately and the oil was able to get to the far end of the system much quicker.)
The block can be further strengthened by tapping the side freeze plug holes and plugging them with cast iron threaded plugs. I believe it takes 1 1/4" iron pipe plugs.
Old 12-24-2011, 08:47 PM   #26
All4sho's Avatar
I will definitely have to print that out. But that is alot of info I will have to keep in mind. Thank you very much!
Old 12-24-2011, 09:13 PM   #27
Re: Intake options?
You're Welcome & Merry Christmas!
Old 12-24-2011, 09:21 PM   #28
All4sho's Avatar
Yes sir thank you and Merry Christmas to you.
Old 12-28-2011, 06:52 PM   #29
Does anyone know if the have a air flow chart for different intake manifolds to compare ?
Old 12-28-2011, 08:16 PM   #30
Re: Intake options?
They are out there, but finding them can sometimes be a chore.
Do some Google searches on the brands you are looking for using various search terms like, intake, air flow, comparison, charts, CFM, etc.etc..
Old 01-02-2012, 10:13 PM   #31
Here's a chart I found on stangnet of different intake air flows
http://www.stangnet.com/mustang-foru.../#post-6462793
5.4 modular swap HPS intake ?? victory181 1996-2004 Mustang GT 0 10-27-2011 06:12 PM
Cracked Intake manifold... bobsurvives 1996-2004 Mustang GT 7 10-16-2011 12:03 AM
Intake Manifold vs Intake Man-child jbanks 1996-2004 Mustang GT 17 08-02-2011 04:55 AM
5.0 Intake cover RED! wnt2gofst Mustang Parts for Sale and Wanted 2 07-04-2011 11:11 PM
03:41 AM
