HELP Please!!! - Mustang Evolution
Old 12-21-2011, 09:00 AM   #1
1994Potter5.0's Avatar
HELP Please!!!
Only when I press the pedal to the floor,I hear a scratching sound! I hope whatever it is doesn't mess up my pistons or crankshaft or camshaft?!! Anybody help diagnose please?
1994Potter5.0 is offline   Reply With Quote
Old 12-21-2011, 09:41 AM   #2
04machazblue's Avatar
What pedal
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-21-2011, 11:52 AM   #3
Gas pedal lol
Old 12-21-2011, 11:55 AM   #4
236mustang's Avatar
Re: HELP Please!!!
do you have oil pressure? check the oil dipstick
could be a bad piston ring or rod bearing but dont hold me on that.
1995 Cammed/Turboed V6 Mustang (auto)
13.3@103mph
Built by Iron Horse Motorsports
236mustang is offline   Reply With Quote
Old 12-21-2011, 11:58 AM   #5
Ok I'll check,that out and see what's up I was thinking about a bad piston,or rod
Old 12-21-2011, 03:05 PM   #6
Get a long screw driver and rev the car.if you put your ear on the handle and the other end on the motor it will help u find the noise.I actually have a stethoscope with a needle on it.works great.but anyways move the screwdriver around start on the intake and heads then move down to the block.then check your accessorys.if the noise is in the block then its most likely pistons/rings.if its in your heads its valvetrain.
Old 12-22-2011, 01:35 PM   #7
Re: HELP Please!!!
timing may be to high
kid_kash_00 is offline   Reply With Quote
Old 12-22-2011, 02:31 PM   #8
Gster's Avatar
+1. Are you using 93 octane? My 95 GT did that if I didn't use 93. I could always tell which gas station was cheating and never went back to that station.
Gster is offline   Reply With Quote
Old 12-23-2011, 02:46 AM   #9
Re: HELP Please!!!
Nah, it's just those hamsters running the drive wheel trying to get some traction.
The guys are correct, you may be hearing some light detonation.
Check your timing and make sure you have good fuel.
12:32 PM
