Mustang stalled today...help please - Mustang Evolution
Old 12-21-2011, 05:09 PM   #1
Matt5.0's Avatar
Today I was out driving around and my car died on me. I was driving about 45 mph heard a few back fire sounds the rpms dropped to about 500-600 rpms. At that point when i would step on the gas it would sputter / struggle. I got my free tow out of my insurance policy and it is at home. Any ideas what may have failed on me. The car will not turn over now. About 6 months ago i replaced the maf sensor. Please help me out before i drop lots of $$$$ on things that are not wrong.
Thanks all for the help!!!
Matt5.0 is offline   Reply With Quote
Old 12-21-2011, 05:24 PM   #2
Re: Mustang stalled today...help please
i had this happen on my GT...luckily i babied it home a 5mph for a mile to my house....turned out to a bad upstream o2.
SonicBoom239 is offline   Reply With Quote
Old 12-21-2011, 05:34 PM   #3
it will not do any thing? almost sound like u were losing power.maybe something electrical.
---------- Post added at 06:34 PM ---------- Previous post was at 06:32 PM ----------
you mean it cranks but wont fire right?if thats the case you need to check ur fuel pressure and then check for spark and start from there.
Old 12-21-2011, 05:39 PM   #4
Gster's Avatar
Make sure you don't have an air leak between your MAF and your throttle body, that will make it run like sh** if it does.
Gster is offline   Reply With Quote
Old 12-21-2011, 05:42 PM   #5
93slowstang's Avatar
Sounds like the fuel pump decided to crap out.
Old 12-21-2011, 05:46 PM   #6
Gster's Avatar
How long has it been since you replaced your oxygen sensors or your fuel filter?
Old 12-21-2011, 06:21 PM   #7
Matt5.0's Avatar
Fuel filter was replaced 1 year ago 3000 miles are on the new fuel filter. Never since i had the car on o2 so unknown
Old 12-21-2011, 06:34 PM   #8
Gster's Avatar
All of those have those symptoms, trying to start cheap and go up. Do you know anyone with a code scanner?
---------- Post added at 09:34 PM ---------- Previous post was at 09:31 PM ----------
I have a code scanner that I used on my 95, but I'm in KY and your in Jersey right?
Old 12-21-2011, 06:37 PM   #9
Matt5.0's Avatar
Yeah at the worst i could get it done at ford for 99 bucks
---------- Post added at 08:37 PM ---------- Previous post was at 08:35 PM ----------
What is the cost of a scanner i would love one for this car since i will never get rid of it
Old 12-21-2011, 06:50 PM   #10
Gster's Avatar
You can get them for less than $99.00. The problem is finding one for your car, most sold today are for 96 or newer. Check with your nearest auto part store.
---------- Post added at 09:50 PM ---------- Previous post was at 09:45 PM ----------
I just checked EBay. Mine is a sunpro CP9015 ford scanner. They have it for 29.99. It worked great for me when I had my 95. Should come with a book so you know what code the beeps are making.
Old 12-21-2011, 08:44 PM   #11
Furious35's Avatar
Region: Arkansas
Just to jump in. If it's fuel related you prob won't get a code. Fuel filter won't go out/bad just out of the sudden. But you are forsure not getting enough fuel possabile your fuel presure regulator or pump. Put a gauge on your fuel rail/shrater valve have a friend turn key on to prime the system and see what pressure you have. If I remember right should be around 50 pounds at prime and 32-38 at idle. Also listen for your pump to make a light high pitch whine if it's deep and draggy sounding it's time for a pump. If all checks out pull vacume line off regulator try to start it if it cranks up runs better there's your problem. Hope this helps
Furious35 is offline   Reply With Quote
Old 12-22-2011, 02:10 AM   #12
Sounds to me like the timing chain may have skipped a tooth or two.
Check your timing while you are at it.
Old 12-29-2011, 07:20 PM   #13
Matt5.0's Avatar
Thanks gster i just got my scanner in the mail today. Have not hooked it up to the car yet but hope to get to it monday.
Old 12-30-2011, 11:58 PM   #14
94 Mustang GT's Avatar
You need 3 things for an engine to run. Air, fuel and spark. Check to see you have bot only fuel pressure about also enough fuel flow. Check to see you have spark. What I'd do first is spray brake clean down the throttle body and see if it starts. If it does you have a fuel problem!
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 01-13-2012, 10:17 PM   #15
Matt5.0's Avatar
Gster, i got the scanner and it gave me 3 codes 511 electronic control assembly problem read only memory test failure 564 electro drive fan circuit failure
558 egr valve regulator solenoid circuit failure
What should i look at replacing.
So far i changed out my fuel pressure reg
And my egr valve position sensor
Does it sound like my vacuum solenoid and or egr valve pressure sensor?
Old 01-15-2012, 08:52 AM   #16
Gster's Avatar
Egr is your exhaust gas recirculating http://www.engine-light-help.com/egr-valve.html
As for the 511 code have you programmed or used a tweecer on the car? If you have disconnect the battery for 20 mins this will clear any changes loaded into the temporary storage. If you still get this code there could be something wrong with your computer.
As for the electo drive fan I believe it has to do with the a/c.
---------- Post added at 11:52 AM ---------- Previous post was at 11:13 AM ----------
If you have a chip it will cause this code also, then nothing to worry about.
---------- Post added at 11:52 AM ---------- Previous post was at 11:52 AM ----------
511 that is
Old 01-15-2012, 09:36 AM   #17
newdub83's Avatar
Region: Idaho
Idk if u have figured this out yet but I had this prob an it ended up being the pip module located inside the distributer, some stangs were assembled with cobra parts like mine was so make sure u get the right 1
newdub83 is offline   Reply With Quote
1969 Mustang Coupe Restoration Project yellow99 Classic Mustangs 5 10-15-2011 10:05 AM
1995 Mustang SVT Cobra Project yellow99 1979-1995 Mustang GT 0 09-03-2011 05:51 PM
1971 Mustang Fastback Project yellow99 Classic Mustangs 0 09-03-2011 05:49 PM
11:42 PM
