Engine mounts - Mustang Evolution
Old 12-22-2011, 12:14 PM   #1
Cm644rodrigues's Avatar
Engine mounts
He 87 vert has horrible mounts. You can see the fan ground away almost an inch. My transmission is starting to make sorta like a light swirling/ rubbing in neutral. When I press in the clutch it goes away. Will bad engine mounts with the dropping of the engine mess anything like the throw out bearing up causing the noise? Thanks all and merry Xmas. Fox body fans are the greatest!
Cm644rodrigues is offline   Reply With Quote
Old 12-22-2011, 01:18 PM   #2
93slowstang's Avatar
No, but it can add unwanted vibration.
Old 12-23-2011, 02:44 AM   #3
Re: Engine mounts
It shouldn't. The noise you are hearing is likely the throw out bearing rubbing on the clutch forks.
The engine dropping down may have affected your clutch adjustment a bit.
Replace the motor mounts and adjust your clutch.
Merry Christmas to you too.
Unsure of my engine Nate98stang 1996-2004 Mustang GT 11 12-13-2011 08:17 AM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
99-04 Mustang GT ENGINE BLOWN!!! HELP!!! FORDGT14 1996-2004 Mustang GT 17 09-16-2011 02:11 PM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
3.8l to 4.6l engine swap important steps zrider07 General Mustang Discussion 2 08-04-2011 09:07 PM
12:36 AM
