Throttle Body Questions - Mustang Evolution
Old 12-22-2011, 11:41 PM   #1
89Saleen141's Avatar
I am really new, I was wondering if I am not planning on forced induction, what would the differences be with the 65, 70, and 75mm throttle bodies on the engine? All I have on the car is a set of long tube headers, flowmasters, and 3.55 gears.
89Saleen141 is offline   Reply With Quote
Old 12-23-2011, 12:49 AM   #2
89 Foxloco's Avatar
First of all welcome!!! Pretty much the difference is better air flow..the bigger the hole the more air that goes in.its like the exhaust system.stock is usually 2 1/2 inches others change it to 3 inch pipes for better flow.hope it helps.
89 Foxloco is offline   Reply With Quote
Old 12-23-2011, 03:02 AM   #3
Re: Throttle Body Questions
Sequentially larger bores with the 75MM likely being too large for your mods.
With stock injectors I'd go with the 65MM.
With 24lb injectors I'd use the 70MM.
You also need to check the size of your intake opening.
A smaller intake opening can cause some unwanted restriction and turbulence in the air flow and possible hanging of the TB blade.
Old 12-23-2011, 06:16 AM   #4
93slowstang's Avatar
Sorry it's bugging me, stock is 2 1/4. And bigger is not always better.
---------- Post added at 07:16 AM ---------- Previous post was at 07:16 AM ----------
+1
Old 12-23-2011, 07:12 AM   #5
deadsp0t's Avatar
+1
The 2 1/2"-3" was bugging me also. Was in the middle of something else and about to hunt it down lol Ty for correcting this slowstang! +++
That's unimpressive
Old 12-23-2011, 07:23 AM   #6
ColeJohnson's Avatar
You don't need anything bigger than stock width of 2.25inches. If I remember correctly its enough flow with that width to support up to roughly 380-400hp. Then you jump to 2.5inches up to 550. Then 3inches will hold you from 550+
2016 Comp Orange GT (current)
Old 12-23-2011, 08:07 AM   #7
Gonna put that to rest too, 2.5 will open it up nicely, but you are correct about running a full 3" exhaust.
Just trying to set it a little more right
http://www.carcraft.com/techarticles...ion/index.html
Old 12-23-2011, 12:28 PM   #8
89 Foxloco's Avatar
+1
My bad on that one..its just I had forgotten about the size since I have the three inch piping..
Old 12-23-2011, 02:54 PM   #9
Thanks a bunch guys. Means a lot.
Throttle body and short throw shifter Mayhem48 General Mustang Discussion 14 01-28-2014 09:22 AM
Throttle Body? 2011CS 2011-2014 Mustang GT 2 11-14-2011 06:28 AM
throttle body question..... gkstang Pre-2005 V6 Mustang 1 08-19-2011 07:21 AM
Throttle Body Whistles GTtopgear General Mustang Discussion 8 08-13-2011 09:24 AM
Throttle Body Spacers jbanks 1996-2004 Mustang GT 5 07-11-2011 08:43 PM
03:23 PM
