vacuum - Mustang Evolution
Old 12-23-2011, 09:14 AM   #1
vacuum
Hey guys. I just tested my car for vacuum and it was at 17. Pretty steady, barley fluctuated. I was wandering what it should be on a stock motor. Cuz I'm starting to think that somebody put a aftermarket cam in it b4 I got the car. Cuz it has one heck on a lope. It's got all new tuneup on it so it ain't missing. But it has stock heads and intake on it. But the car doesn't run like it should. If u drive it easy it does fine amd u can't tell no problem. And as soon as u get on it it doesn't really pick up very well. Amd it's 5 speed amd 410 gears. I've done all the cleaning amd tunein on the maf/tps/iac anf it idles pretty steady no surges or anything just has a lope. That sounds really good but just don't get up and go like it should. I also checked my compression and it was 120 at all cylinders. Spark plugs look good with mabye 5000 miles on them. Any suggestions ?
Robbie94gt is offline   Reply With Quote
Old 12-24-2011, 12:44 AM   #2
Re: vacuum
Healthy stock engine vacuum is usually in the 19" - 21" range.
A mildly cammed engine is usually in the 15" - 16" range.
A fully built engine can be in the sub 12" range.
In my experience the SN95's do feel sluggish compared the the lighter, earlier fox bodies and it takes a considerable amount of mods to overcome the weight and ECU tuning differences.
Old 12-24-2011, 06:33 AM   #3
86TBarHatch's Avatar
Region: New Hampshire
I only have 9.5" to 10" with my fully built motor. My XR282 cam has an overlap so that is what brought it down, plus the single plane manifold.
86TBarHatch is offline   Reply With Quote
Old 01-08-2012, 09:01 AM   #4
How do check vacume on 99 mustang
mcilwraith is offline   Reply With Quote
Old 01-08-2012, 10:07 AM   #5
Re: vacuum
Hook a vacuum gauge to an intake vacuum port.
New Vacuum Lines bobby02V6 Pre-2005 V6 Mustang 5 11-06-2014 10:05 AM
Sea Foam in vacuum line? afree05 2005-2010 V6 Mustang 1 12-12-2011 12:23 AM
Vacuum routing diagram Tj88mustang 1979-1995 Mustang GT 16 11-10-2011 04:01 AM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
10:12 AM
