Condensation Problem - Mustang Evolution
Old 12-25-2011, 07:34 PM   #1
tcdavis66's Avatar
Hey, i noticed my carpet on the passenger side was wet awhile back after taking my son for our first ride together...it was raining that day. Seemed drivers side was wet too. Well haven't had car long and when the weather got cooler I started using the heater...think I probably had it on heat with my son, but don't remember. also had new windshield put in and had guy come back out cause all this seemed to happen after the new windshield, but I 'm 99 percent sure the windsheild is fine and not leaking. I have looked under car and noticed the plug was in the floor board, both sides...the car is lowered but did see the plugs. I think its more likely to be water from the heater core tubing. I put some baking soda down and made a baggy with holes and added some baking soda to it, just to lay down in the floor board. I couldn't feel any moisture like around the edges of the floor board where the carpet goes vertical. Please any advice on how to trouble shoot, fix or previous similar cases would be most appreciative. oh and Merry Christmas
2001 Cobra BBk CAI , Magnaflow Catback,
tcdavis66 is offline   Reply With Quote
Old 12-25-2011, 08:47 PM   #2
jhagan1980's Avatar
Do you have an after market shifter? On mine I had to trim the rubber weather seal that helps keep water and such out. If that's not cut right it could possibly throw water into the cabin.
jhagan1980 is offline   Reply With Quote
Old 12-25-2011, 08:56 PM   #3
tcdavis66's Avatar
Re: Condensation Problem
yes it is. its not even secured
Old 12-25-2011, 11:42 PM   #4
Pressure test Ur cooling system, but more than likely it's Ur heater core.
1fst86 is offline   Reply With Quote
Old 12-26-2011, 02:17 AM   #5
+1 i agree with this.but also check your cowl area.rain and water should be able to drain from that area but if it gets clogged up it can cause this to.
Old 12-26-2011, 08:54 AM   #6
tcdavis66's Avatar
hey dreamstang, where? Is this area inside engine compartment above firewall where wlindshield wipers are?
---------- Post added at 09:33 AM ---------- Previous post was at 09:13 AM ----------
hey 1fst86 I haven't ever done a pressure test. how much money we talking here? most garages near me are expensive as ****...
---------- Post added at 09:54 AM ---------- Previous post was at 09:33 AM ----------
well dang. this morning the carpet is soaked! passenger side...no obvious signs where the leak is. did not drive last nite...temps got down to 32 and lots of moisture in the air so freaking water everywhere. would the heater core leak even when not running the car? and any other tricks to this core swap beside a reducer, careful with tex screws and loosening ac accumulator and having patience (which i don't rite now)
Old 12-26-2011, 09:55 AM   #7
tcdavis66's Avatar
ok, found nice DIY heater core replacement instructions from Trojans helpful links. Looks like it's doable, so let me see what I can do. Still would like to know for sure if this core leaks when just sitting???
---------- Post added at 10:55 AM ---------- Previous post was at 10:42 AM ----------
I just remembered I smelt strong antifreeze smell on way home last time I drove her...its the core! crap
Old 12-26-2011, 10:21 AM   #8
U could try bypassing the heater core for a little while to see if u still get moisture.
Old 12-26-2011, 11:25 AM   #9
tcdavis66's Avatar
well im into "the project" its goin good (so far) kinda like working on the car...that's what its' all about rite?
-->MACH speaker problem... HELP!!!! DaMan Mustang Audio & Video 7 11-27-2011 05:55 AM
Just bought Mach 460 Amp/speaker box... 1 problem though' Black_Sunshine Pre-2005 V6 Mustang 0 10-16-2011 06:42 PM
Problem with OBD Code P0455 tonyjuan 1996-2004 Mustang GT 8 08-24-2011 10:51 PM
Please Help Transmission Problem znpzmustang Pre-2005 V6 Mustang 1 07-26-2011 01:52 PM
Drivers side window problem bullitt1075 1996-2004 Mustang GT 3 07-20-2011 11:47 AM
12:08 AM
