clutch cable issues - Mustang Evolution
Old 12-25-2011, 06:47 PM   #1
clutch cable issues
i have a 89 5.0 and i just installed a new clutch kit and a new clutch cable and im having problems keeping the clutch cable on the billet quadrent. not sure how else to explain it ... any ideas or suggestions would be appeciated thanks
89stang is offline   Reply With Quote
Old 12-25-2011, 07:42 PM   #2
jhagan1980's Avatar
Did you install a firewall adjuster?
jhagan1980 is offline   Reply With Quote
Old 12-25-2011, 08:38 PM   #3
Re: clutch cable issues
shure did ... could the clutch fork have somthing to do with it?
Old 12-25-2011, 08:41 PM   #4
jhagan1980's Avatar
It should be able to be adjusted there as well
Old 12-26-2011, 06:37 AM   #5
Is the cable tight or is the quadrant tilted or on a bent shaft?
Old 12-26-2011, 11:11 AM   #6
04machazblue's Avatar
Maybe u have to much slack
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 12-26-2011, 11:45 AM   #7
the cable stays on the clutch pedal when i push it down ,, soon as i release the pedal it looses tension then comes off the quadrent.
the cable stays tight when pedal is down and when released cable stays there ,, some how its not releasing or staying on the quadrant
Old 12-26-2011, 05:12 PM   #8
Sounds like your TB may be sticking on the front bearing support tube of the transmission.
This is a common problem with those made of aluminum.
The cure is to replace it with a cast iron or steel one.
Old 12-26-2011, 09:31 PM   #9
sounds about right ,, looks like ill be trarin back into the tranny if thats what it is ill surly let ya know thanks
Old 12-27-2011, 07:02 PM   #10
DDubs's Avatar
How about you just bring the car to my place and I'll swap you for my bicycle!
DDubs is offline   Reply With Quote
Old 12-27-2011, 07:18 PM   #11
I had a bicycle once.....but the motor gave out on the first ride I took it on so I put it away in the garage. Where it remains to this day.
Old 12-27-2011, 07:50 PM   #12
DDubs's Avatar
Dude!!! That happened to you too?! That's awesome!!
Old 12-27-2011, 10:30 PM   #13
Yes it did!
I've been eyeballing an old Stihl weedeater engine sitting in the corner.
I bet it will last longer than the original did.
Clutch Issues cblkmore Pre-2005 V6 Mustang 4 10-29-2011 08:19 AM
Clutch cable broke... Need help... BLUE02GT 1996-2004 Mustang GT 4 09-15-2011 10:36 AM
Clutch cable adjustmemt jwhayne0001 1979-1995 Mustang GT 5 08-20-2011 11:51 PM
Clutch issues Black_Sunshine Pre-2005 V6 Mustang 4 08-15-2011 10:15 AM
03 cobra clutch issues. zinc03 SVT Mustang 4 06-24-2011 12:18 PM
02:57 AM
