Wantin some ideas and info - Mustang Evolution
Old 12-25-2011, 07:00 PM   #1
93stangster's Avatar
I am doin my first motor build and am I Tryin to build a 347 to go in my 93... I have the block what would y'all suggest about boring and internal parts...
93stangster is offline   Reply With Quote
Old 12-25-2011, 09:57 PM   #2
WhiteCobra94's Avatar
I'd bore .30-.40 over, for internals depends on what your doing and how much HP your trying to get? But I would always go with forged internals . Is it a stock block? Stock blocks are good for 400-450hp max 500hp
---------- Post added at 11:57 PM ---------- Previous post was at 11:56 PM ----------
D.S.S. makes a 327, 331, and 347 forged stroker kits for entry level street cars for $881
Old 12-25-2011, 10:26 PM   #3
deadsp0t's Avatar
Wouldn't go past .030 over. Anything past that and reliability will become an issue if you if you are building a daily driver.
That's unimpressive
Old 12-26-2011, 06:26 AM   #4
Re: Wantin some ideas and info
Need to know more about what you want to do with the engine.
Old 12-26-2011, 09:27 AM   #5
Well I plan it being a daily driver and a strip car... I am hopin to be pushing around 450 hp and I would like to try to run some where in the 7.5 range on the 8th mile
Old 12-26-2011, 09:44 AM   #6
Are you going to develop that 450 HP with N/A parts or are you going with forced induction?
Old 12-26-2011, 10:21 AM   #7
Well I would rather be n/a if possible but like I said I'm just starting this type of stuff and not sure if I can
Old 12-26-2011, 10:41 AM   #8
captain78's Avatar
If you wanna go N/a it possible but very expensive. Easiest and cheapest is power adder. Nitrous is my fav. Lol. For around $400 you can have 150 horsepower at you becken call.
captain78 is offline   Reply With Quote
Old 12-26-2011, 11:31 AM   #9
You can, but building HP is expensive no matter how you choose to do it.
Even using the cheapest power adder (Nitrous) you should build the bottom end to withstand the additional forces and abuse. Otherwise, eventually you will have a failure.
Start out with all forged, good quality bottom end components (pistons, rods & crankshaft) and you will have a base to add onto.
I would also add a DSS Main Support System and a Valley Girdle Pro to help strengthen the block.
Old 12-26-2011, 02:38 PM   #10
So do y'all think a stock block will be ok... I bought a 5.0 block no pistons notin in it out of a 93 stang it come with a ford racing 347 crank, all for 50 bucks and that was goin to be my start....
Old 12-26-2011, 08:43 PM   #11
Most likely it will be fine.
Is the crankshaft a cast iron or forged piece?
The stock internals will usually hold up to 500 HP if the engine is kept in good tune and you don't pound on it mercilessly.
Old 12-27-2011, 01:55 PM   #12
How can I tell the difference
Old 12-27-2011, 06:40 PM   #13
I don't know for sure, but a machine shop should be able to tell you.
If you got it with the block for $50 I would bet that it is a cast iron crank as the forged ones are much more expensive and I don't see anyone letting one go that cheaply.
Old 12-28-2011, 05:37 PM   #14
Well it was from a friend but he's not sure either
Old 12-28-2011, 08:12 PM   #15
It's possible then.
There should be some numbers or identifying marks on it somewhere.
« Fox | engine code »
09:32 PM
