F cam - Mustang Evolution
Old 12-27-2011, 09:58 AM   #1
Mustang Lilmike's Avatar
F cam
What kind of set up will I need to support the f303 camshaft?
Mustang Lilmike is offline   Reply With Quote
Old 12-27-2011, 10:07 AM   #2
stampde's Avatar
Re: F cam
GOOD SET OF HEADS (with good valve springs ) and intake , headers
if your running stock stuff you'll just be wasting your time , you might as well go with a smaller cam ,you'll make more power
2011 GT Auto
Old 12-27-2011, 02:36 PM   #3
F cam is great for forced induction
Old 12-27-2011, 05:07 PM   #4
Re: F cam
I have gt40x heads 1.7 roller rockers bbk long tube headers and intake manifold 75mm throttle body! What size injectors and mass air should I use?
Old 12-27-2011, 05:34 PM   #5
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
I would say at least 24lb injectors, right now if your using the stock 19 lb ones you may actually be running a little lean with the bolt ons you have.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 12-27-2011, 05:46 PM   #6
Well it's not in the car yet. I have 24 and 30 pounds injectors? I'm thinking going with 80mm mass air? Would I need a bigger fuel pump?
Old 12-27-2011, 07:11 PM   #7
captain78's Avatar
I was told to swap stock pump out with a 190lph fuel pump and I'm gonna be running AFR heads holly systemax upper and lower 70 mm TB 80mm MAF with CAi. 30lb injectors 190 lph fuel pump
captain78 is offline   Reply With Quote
Old 12-27-2011, 07:31 PM   #8
WhiteCobra94's Avatar
Well there is really only a $10 difference between 190 and 255 fuel pumps , if down the road you are gonna use a power adder you'll need a 255. Your fuel pressure regulator will do the rest so my opinion I'd go with the 255 fuel pump !
---------- Post added at 09:31 PM ---------- Previous post was at 09:30 PM ----------
And if your keeping it N/A , 24lb injectors are fine!
Old 12-27-2011, 07:34 PM   #9
Thanks man
Old 12-27-2011, 07:59 PM   #10
captain78's Avatar
Lol yea forgot to mention the nitrous I'm adding to mine
cam gear spacer duffeycycles Classic Mustangs 2 12-03-2011 08:45 PM
Rebuilt aoed, cam question Schlahty 1996-2004 Mustang GT 0 11-10-2011 02:11 PM
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
cam and r/r question l2plagears Pre-2005 V6 Mustang 12 10-04-2011 10:29 PM
What oil should be used on my cam break in? wc3john 1979-1995 Mustang GT 6 08-14-2011 11:43 PM
04:32 AM
