my fuel pump - Mustang Evolution
Old 12-29-2011, 07:31 PM   #1
jacob.a.gasparp's Avatar
Region: Nebraska
my fuel pump
Ok when the fuel pump primes and after I start the car it can sometimes still be heard. That high pitched whine I mean. This is rare and should it be something I should be worried about? Its a 89 gt hatchback by the way.5.0
jacob.a.gasparp is offline   Reply With Quote
Old 12-29-2011, 10:20 PM   #2
Region: Nebraska
Basically. I am saying that the high pitched sound of the priming still goes on continuously sometimes after it is started.
Old 12-29-2011, 10:32 PM   #3
93slowstang's Avatar
Youre not supposed to hear it after it primes. It may be a sign that the pump is going out.
Old 12-29-2011, 10:34 PM   #4
deadsp0t's Avatar
Does it run differently when it does it?
That's unimpressive
Old 12-30-2011, 07:49 AM   #5
Region: Nebraska
It idles about the same and doesnt sound any different or drive different. Im also getting 22.5 mpg so I wouldnt think its pumping a lot of fuel into it.
Old 12-30-2011, 10:03 AM   #6
Re: my fuel pump
It should quieten down once it builds pressure.
May be a bad regulator bypassing too much fuel.
You should do a pressure check and see where it's at.
Should be around 38-40 psi with the vacuum line off at idle I believe.
Use your Chilton's or Haynes manual to verify the pressures and procedure.
Old 12-30-2011, 03:10 PM   #7
Has Ur pump been replaces? Do u know the brand?
1fst86 is offline   Reply With Quote
Old 12-30-2011, 04:28 PM   #8
Region: Nebraska
I am pretty sure everything on it is stock
Old 12-30-2011, 05:41 PM   #9
94 Mustang GT's Avatar
I'd say it's fine, just getting old.
1994 Mustang GT
Bought for $2200,Had 97K miles,New fuel tank,New driver front hub,New pass ball joint,New alt, New battery,New fog lights,New plastic bezel shifter,Fixed check engine light,New tires,Coolant flush,Magnaflow exhaust. Its starting to come together towards stock THEN I will make it go FAST!
94 Mustang GT is offline   Reply With Quote
Old 12-30-2011, 07:42 PM   #10
If ur fuel pressure is fine, then it's jus getting old like he ^ said. I'd have a other one on hand jus in case it may go.
Fuel pump questions Matt5.0 1979-1995 Mustang GT 1 12-23-2011 03:19 AM
injectors and fuel pump CancerBoi69 Pre-2005 V6 Mustang 1 10-14-2011 07:28 AM
Fuel pump? 96 stang 1996-2004 Mustang GT 10 09-21-2011 10:07 PM
Bad Fuel Pump?? jal4411 1979-1995 Mustang GT 7 09-17-2011 02:32 PM
Fuel pump constantly running Albaraptor 1979-1995 Mustang GT 3 08-28-2011 02:55 PM
11:12 AM
