Getting yalls' opinions - Mustang Evolution
Old 12-31-2011, 01:12 AM   #1
jacob.a.gasparp's Avatar
Region: Nebraska
Alright I haven't yet had the time to check into this yet because of work but I think I may have a slight exhaust leak. You can't hear anything when your idling or going a constant speed. But on the driver side of the engine when you are speeding up you can kind of hear a sound that is kind of a mix between a teh and pft sound. Sounds like air or something but I'm not totally sure. Any ideas for me to check on like loose bolts or something?
jacob.a.gasparp is offline   Reply With Quote
Old 12-31-2011, 02:10 AM   #2
Re: Getting yalls' opinions
Tie or tape a small piece of white rag on a stick or rod and with the car running hold it near any joints or bolted connections. Note that you will get some movement from wind, fan airflow, etc., but a leak will usually make it flutter in an easily discernable pattern.
Old 12-31-2011, 09:08 AM   #3
Region: Nebraska
Alright i will try that. Thank you.
Old 12-31-2011, 09:43 AM   #4
88gtCc's Avatar
Also you can spray a mix of soap and water on any spot you think may be leaking. If it bubbles that means you have air leaking
88gtCc is offline   Reply With Quote
Trick flow opinions Tj88mustang 1979-1995 Mustang GT 11 12-04-2011 03:46 PM
96 SVT Cobra appears Superchip is bad opinions on my options please Spiney SVT Mustang 15 11-07-2011 08:34 AM
opinions on clone cars 93cobradude General Mustang Discussion 15 09-03-2011 10:07 AM
opinions on color for 88 fox 04TRV6 1979-1995 Mustang GT 39 07-08-2011 01:30 AM
10:16 PM
