Instrument cluster - Mustang Evolution
Old 01-01-2012, 06:10 PM   #1
captain78's Avatar
Instrument cluster
My cluster lights on dash just stopped working. It's not a fuse issue. Could the bulbs just burn out. 90 gt. Can I just change bulbs or do I have to change hole panel.
captain78 is offline   Reply With Quote
Old 01-01-2012, 06:17 PM   #2
89 Foxloco's Avatar
wel first check that the bulbs are good if not than change them no need to change the whole cluster..they come out really easy..
89 Foxloco is offline   Reply With Quote
Old 01-01-2012, 06:52 PM   #3
captain78's Avatar
Thanks will do tomorrow
Old 01-01-2012, 07:38 PM   #4
89 Foxloco's Avatar
No problem..just after putting my car all apart I know pretty much everything in it..lol
Old 01-01-2012, 09:25 PM   #5
captain78's Avatar
I looked at instrument cluster. How do you get it out lol. Does everything just snap off are do I have to pull hole dash a part. You know drop steering column and all that.
Old 01-01-2012, 09:51 PM   #6
88fox's Avatar
I believe it has 4 bolts 2 on top by windshield and 2 on bottom by steering column
88fox is offline   Reply With Quote
Old 01-01-2012, 09:59 PM   #7
captain78's Avatar
Yea but I'm talking about the plastic that surrounds instrument cluster. No screws just flat surface. Does it just pop off
Old 01-02-2012, 12:36 AM   #8
89 Foxloco's Avatar
If your taking about where the light switch and hazard lights switch is on..two screws on to and two on the bottom..no steering wheel coming off or none of that..
Old 01-02-2012, 05:41 AM   #9
captain78's Avatar
Nah speedo tach and all the gauges.
Old 01-02-2012, 06:03 AM   #10
re: Instrument cluster
Oh no! More instrument panel problems?
Not 100% sure, but a lot of times on Fords the clear instrument panel lenses are held on by plastic studs that are melted down to secure the lense. If that's the case I wouldn't remove it unless I absolutely had to.
Old 01-02-2012, 06:16 AM   #11
captain78's Avatar
Yea Trojan I woulda put it in one thread but heard about a discount when you get 50 of them to am. But yea lights don't work at night with headlights on. Heard it could be dimmer switch also heard it's a very common prob with these cars. But also heard it could be light bulbs. And temp gauge and fuel gauge doesn't work. All other gauges work. Tech speedo check eng. All that works except fore low coolent light lol that one works lol but won't go off. And don't light light just blew. I checked chiltons and then checked fuse box and changed all fuses. Except the CB fuses cause I had to order them but they coming soon. Figured fuel gauge is most likely the sending unit in tank. Dome light is blown light bulb it worked till yesterday lol. Just getting bugs worked out of it after sitting for so long
Old 01-02-2012, 07:14 AM   #12
Be careful of making any frivolous or nonsense posts to get your count up.
The site administrator/owner frowns on that.
What you posted so far should be fine even though it is somewhat related because it may be from different causes.
I thought the count was 100 posts, but I may be wrong. Check each vendor/site supporter's forum for instructions on how to get the discounts.
It could very well be the dimmer switch. The rheostats they use do fail over time, especially if they are used a lot. Just check the input side of the dimmer when the dash lights go out and see if it has power to there. If it does then that is likely the problem.
Old 01-02-2012, 09:50 AM   #13
captain78's Avatar
Ok will check
Old 01-02-2012, 07:59 PM   #14
captain78's Avatar
Well got my fuel gauge working. Put some sea foam in tank and bout a hour later it started working.
Old 01-04-2012, 08:08 PM   #15
captain78's Avatar
Well dimmer switch is working well it turns the dome light on and off but still no instrument lights. Could it be headlight switch not working right
Old 01-05-2012, 08:02 AM   #16
Re: Instrument cluster
Possibly.
Locate the power circuit to the lights on the back of the instrument panel and trace it back to the wire connections and see if you have power there. From there trace the wire back to wherever it gets its power from if necessary.
Old 01-05-2012, 09:52 PM   #17
captain78's Avatar
Ok well changed dimmer switch and headlight switch. And good news is instrument lights came on but only on when dimmer switch has dome light on. Guess I need to break down and buy a new one
Old 01-05-2012, 10:00 PM   #18
Yes, the rheostat portion of the dimmer is not working, so no power gets through to the instrument panel bulbs.
Old 01-05-2012, 10:13 PM   #19
captain78's Avatar
I'm just glad I narrowed it down. Mine was completely shot the one I got from junkyard was free but at least it lit the lights up lol. Might try another one from junkyard. Before I order new one might get lucky 2nd time around.
Old 01-06-2012, 04:26 PM   #20
captain78's Avatar
Just ordered new switch it's on it's way should be here Tuesday can't wait to get dash back together. Guess for now I can work on my brakes.
Old 01-12-2012, 08:19 AM   #21
captain78's Avatar
Got my dimmer switch in and boom lights now everything working now changing front brakes. Rotors calipers hubs bearings rear brakes drums cylinders hardware shoes and whole rack and pinion new hood A/C compressor. And some vacuum leaks. With that all done insurance and plate come next with new headliner and sunroof seal.
Old 01-12-2012, 10:59 AM   #22
Glad you got that sorted out.
2005 gt cluster gauge repair... jmpark527 2005-2010 Mustang GT 29 11-25-2015 09:05 AM
cluster change 88fox 1979-1995 Mustang GT 26 12-02-2011 05:37 PM
does cluster gauge affect sensor?? jmpark527 2005-2010 Mustang GT 0 11-23-2011 08:32 AM
Instrument cluster question Jareds65 Classic Mustangs 1 08-13-2011 12:12 AM
Instrument cluster question matthoffman22 1979-1995 Mustang GT 3 06-25-2011 08:11 PM
10:05 PM
