Changes for 2012 - Mustang Evolution
Old 01-02-2012, 11:15 AM   #1
04machazblue's Avatar
Changes for 2012
Kay so I am doing some major work to the stang I was thinking time for a bigger cam and a better intake. I was thinking like holly or trick flow. And cam wise idk I want a bigger came more lift I was wondering what size cam is the biggest I can go with my heads(gt40x) and switching to 1.7rr,
2004 mach 1(totaled=() 93 mustang lx white
Gt40x heads,e 303 cam, Ford racing 1.6 roller rockers, cobra upper and lower intake, ram air intake, c&l bigger maf, 30lb injectors, Bbk fuel Pressure regulator, double roller timing chain,Bbk shorty headers & h-pipe,flowmasters cat back,chipped,t-5 swap king cobra clutch, 4.10 gears.
04machazblue is offline   Reply With Quote
Old 01-02-2012, 12:34 PM   #2
Titus Wadicus
svtlx's Avatar
Re: Changes for 2012
thats a loaded question when you add 1.7rr to the equation. you will have to run a slightly smaller cam with 1.7rr. i know if you are running e7 heads with a 1.6rr ".544" is your max lift before you need to start notchn pistons. im not sure on cumbustion chamber size for gt40x heads are. i hope this helps you a bit
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-02-2012, 01:14 PM   #3
So stay with 1.6 rr and go bigger cam, I bin doing research and I think
Make lift is 550
Old 01-02-2012, 01:51 PM   #4
Titus Wadicus
svtlx's Avatar
Make lift is 550
i would just stay with the 1.6 if your planning on a bigger cam. it will make your life easier i.m.o.
Old 01-02-2012, 02:57 PM   #5
Meansaleen's Avatar
I use the gt40x aluminum heads an im using I:6 rr and an e303 cam with no problem
Meansaleen is offline   Reply With Quote
Old 01-02-2012, 05:47 PM   #6
I want to make more power
Old 01-02-2012, 05:59 PM   #7
Meansaleen's Avatar
That combo including full exhaust with x pipe , 25 lb injectors and msd ignition system gave me 280 rwhp when I added a vortech s/c I jumped to 470 rwhp. Just to give you an idea
---------- Post added at 07:59 PM ---------- Previous post was at 07:56 PM ----------
Oops typo meant 24lb injectors.
Old 01-02-2012, 06:27 PM   #8
Here's a MM&FF article on the GT40X heads. GT40X Cylinder Heads Install
Look up other articles on that particular project on MM&FF for more information.
Old 01-02-2012, 06:37 PM   #9
Meansaleen's Avatar
Interesting article. Thanx
Old 01-02-2012, 11:23 PM   #10
So ur saying with the similar combo I have ur car dynod around 280
Old 01-03-2012, 05:52 AM   #11
Meansaleen's Avatar
That's what my combo gave me. Mind you that was without a tune i just advanced my timing to 14 deg. I dynoed it before the s/c install to see the difference. With a tune I might've got a few more h.p.
Old 01-03-2012, 05:56 AM   #12
Well my goal is to make 300hp
To the wheels
Old 01-03-2012, 06:24 AM   #13
Meansaleen's Avatar
To the wheels
That'll get you pretty close maybe with a slightly bigger cam a little tuning will net you about 300rwhp.
Old 01-03-2012, 06:27 AM   #14
Well I was considering getting a better flowing intake with a cam too i know with a better c/I combo I will over 300
Old 01-03-2012, 06:36 AM   #15
Meansaleen's Avatar
Can't beleive I left that out lol. I use a vortech intake it's similar to the Holley systemax
Old 01-03-2012, 08:14 AM   #16
Why not go with the Trick Flow HCI kit then?
I read where using one of their kits claims 360 HP.
That would put you at your goal pretty easily, no?
Old 01-03-2012, 08:15 AM   #17
Meansaleen's Avatar
+1
Old 01-03-2012, 10:12 AM   #18
I totally would but I don't won't to
Put out the money for the whole kit
Old 01-03-2012, 09:52 PM   #19
But look what you could get - Trick Flow Top End Kit Dyno Run
12:23 PM
