Egr valve - Mustang Evolution
Old 01-02-2012, 06:10 PM   #1
Matt5.0's Avatar
Egr valve
So my 94 5.0 will now start but runs really poor. It idles at around 300-500 rpm now sounds like it is struggling to stay running. Will shut off after a few min. Does not respond at all when given any amount on the gas. Changed out my maf, wanted to know if this sounds like a bad egr valve? What are other signs of bad egr valve? I thought it was fuel pump but i hear it turn on then thought fuel pressure regulator but really dont think that is it. Please help me out if anyone has had this happen to them.
Matt5.0 is offline   Reply With Quote
Old 01-02-2012, 06:29 PM   #2
Re: Egr valve
Sounds to me like you don't have enough fuel/pressure.
Old 01-02-2012, 08:42 PM   #3
Matt5.0's Avatar
So what is the stock fuel pressure on a 94 5.0 if i get an ajustable fuel pressure regulator?
Old 01-02-2012, 09:04 PM   #4
OG86GT's Avatar
Stock fuel pressure should be around 32 psi at idle
---------- Post added at 11:04 PM ---------- Previous post was at 10:57 PM ----------
I'm also aware that every car is not the same so u should try using a fuel peessure gauge when u get ur regulator
---------- Post added at 11:04 PM ---------- Previous post was at 11:04 PM ----------
*pressure
OG86GT is offline   Reply With Quote
Old 01-02-2012, 09:12 PM   #5
Re: Egr valve
I don't have the manual for a 95 anymore, but I think it is 38-40 psi at idle with the vacuum hose removed from the regulator.
Pick up a Chilton's or Haynes manual if you don't already have one.
They have lots of useful information.
Old 01-02-2012, 09:15 PM   #6
OG86GT's Avatar
+1
Valve covers!!! Coreyw428 1996-2004 Mustang GT 22 12-12-2011 10:53 AM
valve cover gasket..... rinfield2004 SVT Mustang 4 12-09-2011 12:43 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
Egr valve and evr tbonestang 1979-1995 Mustang GT 18 08-03-2011 04:59 PM
07:52 PM
