windshield/turn signal switch - Mustang Evolution
Old 01-02-2012, 08:56 PM   #1
jacob.a.gasparp's Avatar
Region: Nebraska
Ok my turn signal will work same with bright and dim lights but no wipers. The previous owner had a toggle installed to try and bypass the switch all together and was done wrong because it turns the radio on. When the toggle is turned on and the wipers are activated the silver box where all the wires run to from the switch makes an electrical vibration sound and when toggle is off i get nothing. Should i just replace that little bow for starters. Haynes doesnt say much on this.
---------- Post added at 09:56 PM ---------- Previous post was at 09:34 PM ----------
Its a 89 gt foxbody
jacob.a.gasparp is offline   Reply With Quote
Old 01-02-2012, 09:24 PM   #2
Re: windshield/turn signal switch
Its a 89 gt foxbody
That's scary.
Whenever people start hacking on the wiring without knowing what they are doing it usually leads to even more problems.
Start by using your Haynes manual to trace the wiring and make sure it has not been comprimised. Remove the toggle and repair the connections used for it. Once everything is back in order you can start testing to see exactly what the problem is and maybe save yourself some money by not buying things you don't need.
Trace the wires with the manual and see what the silver box you are talking about is used for.
On off switch next to my hood release? Pola25 2005-2010 Mustang GT 10 12-27-2011 01:35 PM
Lane Change Turn Signal Jeffola 2011-2014 Mustang GT 15 11-09-2011 03:14 PM
94 aode to t5 neutral safety switch??? stangwheeler 1979-1995 Mustang GT 5 09-09-2011 05:30 PM
back up light switch 00STANG00 Pre-2005 V6 Mustang 3 09-04-2011 03:19 AM
Clutch switch??? 94GTx306 1979-1995 Mustang GT 12 08-17-2011 01:26 PM
10:02 PM
