5.0 Dying Issue - Mustang Evolution
Old 01-04-2012, 08:30 AM   #1
5.0 Dying Issue
I purchased my mustang about 6 months ago and the pervious owner stated he changed the fuel pump on it. My issue is when I am over 100 miles on a full tank of gas my mustang will die when stopping. I believe it has something to do with the MAF but with what I have noticed with the fuel it seems it could be the fuel pump. This issue doesnt happen when I have a full tank of gas.
Basically Stock 1990 Mustang GT
5 Speed
Ceramic Coated Headers, GT40 intake other than that completely stock
Please let me know if you guys need anymore details to help me diagnoise this problem, thanks for the help.
bbecker is offline   Reply With Quote
Old 01-04-2012, 09:00 AM   #2
Try the idle air control valve
Kjohnson1 is offline   Reply With Quote
Old 01-04-2012, 10:36 AM   #3
Titus Wadicus
svtlx's Avatar
Re: 5.0 Dying Issue
its possible the pump is bad. sounds like the pump is overheating when the fuel level gets low. just a suggestion...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 12:12 PM
EVAP issue plaguing Mustangs! fluffyGT06 General Mustang Discussion 2 12-01-2011 11:56 AM
Watch 5.0 Magazine test AmericanMuscle's 2011 V6! AMDanBailer 2011-2014 V6 Mustang 0 10-19-2011 12:47 PM
2011+ 5.0, lets have a poll on issues DDTCM 2011-2014 Mustang GT 36 09-14-2011 05:56 AM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 04:49 AM
06:38 AM
