Fuel injectors? - Mustang Evolution
Old 01-04-2012, 08:42 PM   #1
WhiteCobra94's Avatar
Fuel injectors?
Hey guys I'm looking for 24lb fuel injectors, what's the difference with these two 24lb fuel injectors ?
(example pictures)
ID:	37329   Click image for larger version
Old 01-04-2012, 09:52 PM   #2
93slowstang's Avatar
The connectors and body style. Ones on the left should be the ones for your car I believe.
Old 01-04-2012, 10:08 PM   #3
Re: Fuel injectors?
ones on right look like EV6 which are indeed for 05+. SO you would need the ones on left.
Old 01-04-2012, 10:15 PM   #4
Ok sweet thank you !!!
Old 01-05-2012, 08:37 AM   #5
Meansaleen's Avatar
(example pictures)
I have a set of 24lb injectors and 42lb injectors if you're interested.
Meansaleen is offline   Reply With Quote
Old 01-05-2012, 12:47 PM   #6
I ordered a set of 24lb last night. Thanks tho!
Old 01-05-2012, 12:51 PM   #7
Meansaleen's Avatar
No prob. Anytime
Old 01-05-2012, 06:05 PM   #8
Lapida's Avatar
You stang is GT?
24lb injectors are factory of the 94 Cobra. Also you need to calibrate the MAF to the new injectors.
Lapida is offline   Reply With Quote
Old 01-05-2012, 06:14 PM   #9
I know but my car has 140,000 on those injectors so I'm buying all new parts with new motor , just wasn't sure what the difference was between the injectors in the 2 pics I posted , I also bought the granatelli motorsports 75mm mass air sensor for the 24lb injectors
---------- Post added at 08:14 PM ---------- Previous post was at 08:12 PM ----------
Along with the JLT CAI, 75mm throttle body and my edelbrock performer intake inlet opening ported from 70mm to 75mm with polished runners
Old 01-05-2012, 06:19 PM   #10
Lapida's Avatar
Sounds good.
My car with a combo like yours and crane camshaft produce 255rwhp and 321tq.
Good luck 😉
Old 01-05-2012, 06:25 PM   #11
Thanks, I have new edelbrock performer 5.0 heads and trickflow stage 1 cam, longtube headers bassani x-pipe and just swapped my American thunder 40 series out with super 10 series! So I'm definitely excited for the spring!!!!
Old 01-05-2012, 06:37 PM   #12
Kyle94GT302's Avatar
Do you know how much hp you are putting down currently? Also what all do you plan on doing to the new motor? I am about to start my motor build for my 94 gt so trying to soak up all info I can lol
98 GT- Full PI swap, 93 tune, 3:73 gears,off-road h-pipe,flows, ported plenum and spacer, mac cai, lowered on eibach springs and eibach shocks and struts,spec stage 2 clutch, pro 5.0 shifter
94gt-H,C,I exhaust, eibach suspension--SOLD
Kyle94GT302 is offline   Reply With Quote
Old 01-05-2012, 07:03 PM   #13
I'm keeping it N/A (naturally aspirated) I'm in the process of swapping motors now , just finishing spraying my engine bay this week. I bought a 302 shortblock bored .40 over to a 308, edelbrock performer heads, performer 5.0 intake ported and polished, trick flow stage 1 cam, pulleys, full exhaust with longtube headers, sct-4 bank chip, I'm not 100% sure but from talking to other guys and girls on here and friends , I'll be around 290-320wrhp, hopefully closer to the 320wrhp mark but well see!!!
---------- Post added at 09:03 PM ---------- Previous post was at 08:55 PM ----------
I have a few pics on my motor in my profile
1995 3.8 Mustang Knocking Sound <Transmission> Fuel Injector<AOD????? HELP> Jsan105 Pre-2005 V6 Mustang 2 10-26-2011 07:24 PM
injectors and fuel pump CancerBoi69 Pre-2005 V6 Mustang 1 10-14-2011 07:28 AM
Fuel injectors ?? stangstar92 1996-2004 Mustang GT 3 10-05-2011 04:59 PM
Fuel Injectors? jjsg09 1996-2004 Mustang GT 1 09-16-2011 08:10 PM
Fuel injectors 2001 v6 Mustanglife Pre-2005 V6 Mustang 9 07-02-2011 10:36 AM
10:11 PM
