racing tonight, any tips? - Mustang Evolution
Old 01-06-2012, 02:51 PM   #1
I have a 5.0 lx stick. I have been going to the strip for a few years now but I am always up for new tips. I know the basics and probably already know what most of you will say but if you have any special techniques to get better ETs, I'm all ears. I'd like to know where you all rev your cars to before you takeoff, what your shift points are, ant what psi you put your tires to. Again, i am not new to this but I'm still a little new to this specific car (ive only gone and raced it about 15 races in about 3 different nights)
nickel501989 is offline   Reply With Quote
Old 01-06-2012, 03:42 PM   #2
captain78's Avatar
Well I've never been to track with my stick so can't help there but with my auto. I have a 2500 stall and can stall up to 3000 and flash at 3500 with slicks. Not drag radials. Never had a set. And air pressure I ran about 15 psi
---------- Post added at 04:42 PM ---------- Previous post was at 04:39 PM ----------
Trick is to make sure both tires have the same pressure summit actually sells a duel pressure gauge that hooks to both tires and same time to make sure both tires have equal pressure
captain78 is offline   Reply With Quote
Old 01-06-2012, 03:49 PM   #3
Oh, i never heard of that product, i might have to look into it and what links of tires do you use? I'm usually at about 25 psi but i have regular street tires for now.
Old 01-06-2012, 03:55 PM   #4
captain78's Avatar
I had some old hoosers idk what air pressure they were suppose to have. But that what I ran.
Old 01-06-2012, 03:59 PM   #5
Ok, thanks, yeah, I've been starting out at around 2500 too and I might try a little lower psi but I don't want to get too low because I'm running on street tires.
Old 01-06-2012, 04:29 PM   #6
captain78's Avatar
Yea street tires are different then slicks big time. I wouldn't go to low on the pressure cause you'll damage the side wall of your tire. And street tires also are not designed to heat up like slicks are
Old 01-06-2012, 04:35 PM   #7
Yeah, i was gonna try somewhere between 23 and 24 and see if it is any better than 25 like i have been doing.
Old 01-06-2012, 04:58 PM   #8
Re: racing tonight, any tips?
What works for one car usually doesn't for the next.
There is a fine line in the rpm's between bogging the engine and blowing the tires off when running street tires.
Try starting at 2500 rpm and go up or down from there until you discover the optimum for your car.
The same applies to tire pressure. Stay at 20 or above for street tires to keep from spinning the rim inside the tire and experiencing bad handling on the other end. Maybe a bit higher depending on your HP level.
Old 01-06-2012, 05:34 PM   #9
FORDGT14's Avatar
Just like all you posts lol
Very very well spoken
FORDGT14 is offline   Reply With Quote
Old 01-06-2012, 06:06 PM   #10
Thank you. "Years" of experience to draw on, when I don't forget that is.
Old 01-06-2012, 08:07 PM   #11
OG86GT's Avatar
I had a friend with an 87 lx
Bbk equal lengths
H pipe and flowmasters
3.73 gears
He ran a 13.82 @99 leaving at around 1200-1500 rpm on 19 psi on street tires but every car is different u gotta see what works for you
OG86GT is offline   Reply With Quote
Tips & Rumors Brent 2011-2014 Mustang GT 1 04-21-2017 04:06 AM
Drag Racing Tips skyline247 At the Track 32 03-21-2016 01:36 PM
Plasti dip pin stripe tips tdurham19 Mustang Paint, Appearance & Detailing 2 12-15-2011 11:31 AM
drag racing tonight godsdisciple85 2011-2014 Mustang GT 42 10-29-2011 12:01 AM
12:02 PM
