H pipe fitment - Mustang Evolution
Old 01-07-2012, 09:55 AM   #1
jwhayne0001's Avatar
H pipe fitment
Installed cat backs and an OR h pipe and my h pipe is hitting on my transmission crossmember on the left hand side is there anyway to bring it down? I loosened it up but cant pull it down, it only hits under heavy throttle or over bumps
jwhayne0001 is offline   Reply With Quote
Old 01-07-2012, 02:03 PM   #2
What brand cat-back, h-pipe?
1fst86 is offline   Reply With Quote
Old 01-07-2012, 03:21 PM   #3
Flowmaster American thunder, and bbk off road H
Old 01-07-2012, 03:26 PM   #4
Re: H pipe fitment
What type of hangers do you have?
Old 01-07-2012, 03:29 PM   #5
The h pipe has the bolt on hangers using rubber mounts, and the cat back is using rubber mounts as well
---------- Post added at 04:29 PM ---------- Previous post was at 04:28 PM ----------
Also it's like a 1/8 inch away from the tranny crossmember would it hurt to put a peice of high temp rubber to act as a bumper?
Old 01-07-2012, 03:36 PM   #6
Re: H pipe fitment
Using rubber could lead to a fire if the pipe got pushed up against it long enough. I wouldn't do that.
Can you extend the hangers or maybe loosen them and see if there is any slack in the mounting holes?
Old 01-07-2012, 03:40 PM   #7
I could possibly dremel the holes into a longated oval shape if there is enough meat to work with so to speak
Old 01-07-2012, 07:32 PM   #8
In what order did u tighten the exhaust up
Old 01-07-2012, 09:15 PM   #9
Front to rear
Old 01-07-2012, 09:28 PM   #10
Check Ur motor mounts, I had an issue with a bbk h-pipe fitment similar to urs but mine was at the front of the passenger side pipe by the k-member. I just left everything loosely bolted in place while l got it to fit correctly.
Old 01-08-2012, 06:24 AM   #11
I'm going to loosen everything up, have someone hold down on the pipe and crank then bolts and nuts down hoping it will stay in place and if not I will elongate the mount bolt holes a little
Old 01-08-2012, 08:42 AM   #12
Re: H pipe fitment
I was just going to suggest something along those lines.
Old 01-08-2012, 08:44 AM   #13
Great minds think alike!
Old 01-08-2012, 10:04 AM   #14
Re: H pipe fitment
Hahaha! Yes, they do. Problem solving at its finest.
Myths about "back-pressure" Eturner General Mustang Discussion 45 09-08-2016 01:31 PM
x pipe or h pipe shsfresh87 1996-2004 Mustang GT 9 12-30-2011 12:41 PM
3.8 Dual Exhaust ssaleen1981 Pre-2005 V6 Mustang 27 12-18-2011 06:43 AM
X pipe vs H pipe ercolanom1 General Mustang Discussion 3 10-21-2011 02:09 PM
Axle-backs now...X pipe and more later? illestdomer2005 2011-2014 V6 Mustang 5 08-07-2011 06:55 PM
12:51 AM
