01-08-2012, 08:09 PM
#1 | | Registered User
| Got my new wheels
Bad pic because car was at an angle, but you get the idea. The rear springs need to be swapped out because I had lifter springs in it from my huge wheels and tires I had on it. Once it's level it should look good again.
Also looks like I can't type a title for crap! Sorry.
__________________ |
01-08-2012, 08:55 PM
#2 | | Moderator
Looks good, def gotta change those rear springs.
01-08-2012, 09:02 PM
#3 | | Blog Manager
They look good
__________________ Layla - December 2010 Mustang of the Month |
01-08-2012, 10:44 PM
#4 | | Senior Member
| Re: Got my new wheels Quote:
Originally Posted by 86TBarHatch Bad pic because car was at an angle, but you get the idea. The rear springs need to be swapped out because I had lifter springs in it from my huge wheels and tires I had on it. Once it's level it should look good again.
Also looks like I can't type a title for crap! Sorry. | Whoa! That's a killer rake!
Back in the 60's and 70's you would have been the "man" with that look.
The wheels look great!
P.S. Fixed the title for you.
01-08-2012, 11:31 PM
#5 | | Registered User
They look real clean on the car! And I heard making it look like your car was going down hill was cool back then!! It doesn't look to bad!
01-09-2012, 06:27 AM
#6 | | Registered User
Nice wheels man!
01-09-2012, 10:25 AM
#7 | | Senior Member
Originally Posted by Timm04 They look real clean on the car! And I heard making it look like your car was going down hill was cool back then!! It doesn't look to bad! |  It was in the 60's and 70's. It was a contest to see who could get their cars @ss the highest in the air.
Sometimes if they went high enough it was an engine killer for the Chevrolet's and their rear sump oil pump pickups, but most Fords had front sump oil pump pickups, so they were ok.
01-09-2012, 10:35 AM
#8 | | Registered User
I wish sometimes I was around the muscle car scene back then!! Those kind of cars will always be classics! I feel like you gotta appreciate what's its come from to appreciate what it is today! Being 19 ive learned alot about appreciating cars but those days sound like so much fun!
01-09-2012, 11:03 AM
#9 | | Registered User
I wasn't around in the muscle car era (I'm 32) but I always loved the look and that's why when I built this car when I was 16 (1995) I raked it.
01-09-2012, 11:31 AM
#10 | | Registered User
Originally Posted by Trojan Horse  It was in the 60's and 70's. It was a contest to see who could get their cars @ss the highest in the air.
Sometimes if they went high enough it was an engine killer for the Chevrolet's and their rear sump oil pump pickups, but most Fords had front sump oil pump pickups, so they were ok. | REMEMBER AIR SHOCKS ?
__________________  2006 Tungsten grey v6 Pony package
01-09-2012, 11:37 AM
#11 | | Senior Member
Originally Posted by stampde REMEMBER AIR SHOCKS ?   | Yes I do!
I was the proud owner (back then of course) of several sets.
I loved the ill handling, conestoga wagon ride and all!
01-09-2012, 11:38 AM
#12 | | Senior Member
Originally Posted by 86TBarHatch I wasn't around in the muscle car era (I'm 32) but I always loved the look and that's why when I built this car when I was 16 (1995) I raked it. | What size tires and rims do you have on the back?
What backspace are the rims?
01-09-2012, 11:51 AM
#13 | | Titus Wadicus
Originally Posted by stampde REMEMBER AIR SHOCKS ?   | lmao... i had sum on my 84 camaro with 265/65/15 rear. back in 97, and im 34.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
01-09-2012, 11:59 AM
#14 | | Do The Evolution
| Quote: |
REMEMBER AIR SHOCKS ?   | I had em on my '86 Grand National! I thought I was the shiet back then. It had Monte Carlo SS wheels.
01-09-2012, 03:38 PM
#15 | | Registered User
Originally Posted by Trojan Horse What size tires and rims do you have on the back?
What backspace are the rims? | They are Mickey Thompson Sportman pros. They are 13.1" wide with a 10.4" tread width. I have them on 10" or 11" wide American racing rims with a 3.5" backspace IIRC.
01-09-2012, 04:06 PM
#16 | | Senior Member
Originally Posted by 86TBarHatch They are Mickey Thompson Sportman pros. They are 13.1" wide with a 10.4" tread width. I have them on 10" or 11" wide American racing rims with a 3.5" backspace IIRC. | OK, Thanks!
I have 295/20/15 tires on 10" rims with 5.5" backspacing, which is not quite enough backspacing to get them tucked into the rear fender wells. Not wanting to buy another set of rims I plan to take about 1" off of each side of the rear end which should allow me to get them up under there.
01-09-2012, 04:33 PM
#17 | | Registered User
Nice
