87 5.0 speedo upgrade: help? - Mustang Evolution
Old 01-08-2012, 09:50 PM   #1
Hello, I want to switch my 85 mph speedo to a 140 mph speedo. I have read many threads, but still do not understand.
1) would it be better to switch out the speedometer only, or do I have to (or would it be less trouble) to just switch out the entire speedo cluster as a unit?
2) i understand i will need to install a new speedo gear, which i believe is located at the transmission end of the speedo cable. Could someone let me know which speedo gear i will need to make the 140mph speedo function correctly? part numbers and/or links would be great.
3) my 1987 lx has 1:3.55 differential gearing. Does that fact change the analysis in #2, above?
Thanks very much.
Buckallred is offline   Reply With Quote
Old 01-12-2012, 06:50 PM   #2
Region: Iowa
Here is what I did;
I found a 89 gt in the junk yard that had a 140 speedo so without a second thought I pulled the whole cluster and went home. I pulled out the old and put in the "new" without paying attention to the different shape of the cluster. (airbag models are different) nothing worked correctly.
So I swapped out just the speedo by taking apart the whole cluster pretty much and put in the old cluster with new speedo guts and face plate. Very minor modification. Works just great, looks stock and nobody would ever be able to tell how I did it. I didn't have to change the gear in the trans or anything other then what I said here.
I'm not a mechanic at all, just a stubborn do it yourselfer
Ps mark your fuel and speedo needles placement somewhere OFF of the face plate.
Bensfoxbody is offline   Reply With Quote
Old 01-12-2012, 07:00 PM   #3
Region: Iowa
Sorry about the flashlight pic, lighting sucks in my garage.
Old 01-12-2012, 09:43 PM   #4
Re: 87 5.0 speedo upgrade: help?
Thanks very much.
I had to R&R just the speedometer in the gauge cluster on my 86 GT.
I did not have to do anything else.
Old 01-12-2012, 09:48 PM   #5
Region: Iowa
I wish I would have explained my post like this haha, sometimes I ramble
Old 01-13-2012, 07:28 AM   #6
Sometimes I do too.
I was just to tired to type anymore than that.
Old 01-13-2012, 08:11 AM   #7
Region: Iowa
One more tip, check your light bulbs while your are in there..... I took mine out twice because I forgot to replace a few the first time. (i actually did all at once to avoid a #3)
Old 01-13-2012, 11:09 PM   #8
Dumb question . . . What light bulbs are you talking about?
Old 01-14-2012, 04:30 AM   #9
He's talking about your instrument panel bulbs.
Old 01-14-2012, 12:19 PM   #10
Region: Iowa
Yeah sorry I should have specified that
Old 01-19-2012, 11:45 PM   #11
Where are the instrument panel bulbs located?
Old 01-20-2012, 02:06 AM   #12
In the back of your instrument panel under some twist out plugs I believe.
Injectors not pulsing? Otlaw80 1979-1995 Mustang GT 21 07-27-2014 04:12 PM
My official 5.0 engine swap thread PureVenom 1979-1995 Mustang GT 35 10-06-2013 01:12 PM
Watch 5.0 Magazine test AmericanMuscle's 2011 V6! AMDanBailer 2011-2014 V6 Mustang 0 10-19-2011 01:47 PM
2011 V6 versus 2012 GT 5.0 avengnd General Mustang Discussion 6 09-01-2011 05:49 AM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 05:08 PM
02:11 AM
