Has any one use seafoam before? - Mustang Evolution
Old 01-08-2012, 09:19 PM   #1
phastang's Avatar
I'm about 200 miles from doing a tune up and was considering seafoam, who has used it? And is it worth it? Notice any difference after using it?
phastang is offline   Reply With Quote
Old 01-08-2012, 10:08 PM   #2
Taxman's Avatar
I have used it several times on lawnmowers 4 wheelers an in my ole diesel..... If your fuel system is dirty it will push it through (clean it out) be ready for a very rough running motor.... From my experience with it it works well.
---------- Post added at 11:08 PM ---------- Previous post was at 11:07 PM ----------
I'd be kinda careful with it. You don't want to clog anything up!!
Taxman is offline   Reply With Quote
Old 01-08-2012, 10:17 PM   #3
captain78's Avatar
It is the shiznik. I love it. You can put it in your gas tank your crankcase or run it through your intake system through one of your vacuum lines. If seafoam don't fix it you need a mechanic. But becareful you must follow directions to the letter.
captain78 is offline   Reply With Quote
Old 01-08-2012, 10:38 PM   #4
Re: Has any one use seafoam before?
I used it in my utility tractor's diesel engine.
I haven't noticed any difference yet, but that may be because I haven't ran all of it through yet either.
I put it in because the fuel system appeared to be gummed up and a couple of injectors were not working properly.
Old 01-08-2012, 10:43 PM   #5
austinknoll's Avatar
I used it once and it made people freak out my motor runs great. It's the beat out there next to Lucas fuel additive
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 01-08-2012, 11:33 PM   #6
Timm04's Avatar
Glad you started this thread I was wondering the same thing! And thanks everyone for the answers
Timm04 is offline   Reply With Quote
Old 01-09-2012, 12:27 AM   #7
89 Foxloco's Avatar
Probably its a dumb ? But can someone tel me whats the seafoam..I hear alot about it but never really asked about it..thanks..
89 Foxloco is offline   Reply With Quote
Old 01-09-2012, 05:02 AM   #8
phastang's Avatar
I'm buying the seafoam today, I sure hope instructions come with it lol...
Old 01-09-2012, 05:57 AM   #9
Taxman's Avatar
What's what about the seafoam?
Old 01-09-2012, 07:01 AM   #10
captain78's Avatar
Seaform is like an fuel additive. Helps clean your engine. But you can add it to you fuel sysytem or put it In your oil or put it in your vacuum line for you intake. When added to your gas tank it cleans your tank sensor fuel lines injectors etc etc etc. When added to your crankcase cleans oil lines crank oil pan removes any moister build up if any. When added to vacuum line cleans your intake. Just be sure to read directions and follow to the T.
Old 01-09-2012, 07:02 AM   #11
captain78's Avatar
You can also go to YouTube there's a guy putting it in his vacuum line to clean intake on a mustang
Old 01-09-2012, 09:37 AM   #12
For me it just made white smoke didn't see or feel any improvement
tbonestang is offline   Reply With Quote
Old 01-09-2012, 10:18 AM   #13
Note: A lot of people buy stuff like Sea Foam, Lucas treatments, etc., expecting miracles.
They are not a cure all for mechanical ills, but it will clean and de-moisturize your fuel system along with several other things.
You may or may not notice any benefits depending upon the severity of your problems or if any even existed in the first place.
Please keep that in mind when buying products like this and you won't be so disappointed when you don't really notice a difference.
Old 01-09-2012, 03:13 PM   #14
89 Foxloco's Avatar
Oh ok..il take that in consideration...thanks for the explanation..I'll probably put some this week since an running it for the last time at the tracks on thursday...thanks..
seafoam Mr. SoloDolo 2005-2010 V6 Mustang 3 12-29-2011 02:12 AM
seafoam 98mustang11 Pre-2005 V6 Mustang 45 12-06-2011 10:39 PM
12:40 PM
